one of the sickest third gens ive seen!
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Went down to the strip today, and this thing shows up, ive never seen or heard about it! sports full tube chassi, fiberglass doors and front end, twin chutes, air shift, 106mm turbo, 6" down pipe, air/water intercooler..just as this thing was about to make a shakedown, it started raining and they shut the track down...heres some pics i snapped in the pits though, enjoy!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
From the high mounted external third brake light, that's a 1986. That sure is a huge rear wing. 2 chutes means it should run at least 180 mph.
Car: 91 z28
yep, i was betting on 7's but they were only going to do 1/8 shakedowns as this is the first time out, they said a "conservative" 1200rwhp.....that paired with the turbosmart electonic boost controller in the cockpit tells me this things got lots on the table still
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
**** dude, no ideas you!
that thing was here in jville? damn 2nd shift.
Hotrodboba400
12-10-2019 07:07 PM
