will these slicks fit?
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
im using factory 16'x8' wheels
i wanna run 26x11.50 - 16 M/T E.T streets what would put me at a 10 inch tread width
will thes fit my rim or am i gonna have clearance problems?
or should i use the 26x10.5 -16 ????
anyone else use these sizes???
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i have 275/50-15 MT drag radials.. its the same thing as a 26x11.5 but it has a wider section width.. it will fit.. if you have 4.5" backspacing, its all good..
do the stock wheels have 4.5inch backspacing???
Car: 91 camaro
Engine: 383 demon 750 rpm heads 150 shot no
Transmission: bto 700r4 stage 3
Axle/Gears: currie 9" 4:10 true track
The stock wheels you have the front are 4.5 backspacing the rear are 5 1/8 or 5 1/4.
I have the 26x11.50-16 ET Streets on my car with stock 91-92 Z28 wheels. They are slightly taller than the 26x10.50-16 ET Streets, so you should use a 3.42 or numerically higher rear end ratio. (I see you have 3.73's, just letting other people know). I had to slightly modify the inner wheel wells where the LCA mounts. Nothing major, just a slight bend.
New2Chevy
09-28-2015 12:35 AM
