few pictures of the machine
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
496 is done and will be to the track this weekend for a flog, I re-did the dash with auto meters and a shift lite in the cig lighter hole, also did the reverse gear pattern on the console for the quarter stick, some of the 8 point s&w is visible too.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
sexy!
A few questions if I may:
did you make the gauge panel? what material?
how much did those gauges set you back, if I may ask?
What was the 11.27 with? what are you expecting now?
Car: 1982 Trans-Am
oh ok, I've heard of aluminum for that, wasn't sure if it was the norm, or just what some guys have done. I figured a sheet of ABS, since it'd look somewhat stock.
$1000 eh? Yea, that's about what I thought I was hoping there was a loop hole or something, $1000 for gauges is pretty damn hard for me to justify...
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
That bbc just looks at home in there. nice job and how well did that s+w cage go in?
that's a big carb....but it looks good.
sexy!
the 11.27 was 2 yrs ago, maybe three and was on a cool october day with a 10.25 454 with a solid lift .620/ 260 duration cam merlin heads and a 175 shot I borrowed from a freind, I only used the shot for third gear too. I`m expecting to see some 10 timeslips, the car wasa struggling with the last motor to get out of the 11.50 range on motor with a 3.70 cog, this engine should be laying down another 100-150 horse so traction will be even worse I assume but this has always been a sandbagger since I`ve owned.
here are two other pictures from the summer, the cage is installed in the side view shot with the 28 inch ET streets and I did edge out the chevelle in the other picture
Car: 1982 Trans-Am
hmm, what brand of gauges were those that were only that much $?
I didn't think you'd be able to get them in the stock setup, but it sure looks clean.
Do tell about the brand though, I only know of autometer, and the ones that would be mountable like that tend to be $$$$... (compared to the cheesy ones that just bolt onto your dashpad or something).
Car: 1987 Trans am
Engine: Cammin Ls1
Thanks for the help. man that thing is going fly are you running a trans brake? i have a th400 and i absolutly love the tranny brake.
Car: 1982 Trans-Am
all you need is the white plastic frame and the outer bezel and plenty of time with carbide cutters
That's what I was thinking, buy them, cut the holes in *some plate of choice*, then push them into place and tada! I figured you'd have to shoehorn them into place with some kind of mounting hardware..
yes the gauges look just like they do know when you buy them, there is a retainer that bolts to the rear of each gauge. The frame I used is the stock cluster frame with all of the stock gauges removed, printed circut board, plexi glass and metal trim bezel. then gutted basically to accept the new ones, also the outer bezel is the stock one opened up by a grinder to accept the aftermarket gauges. shoehorn is a good word to describe the job!
New2Chevy
09-28-2015 12:35 AM
