rear end
Car: 82 Camaro Z28
Engine: 5.7 350
Transmission: Turbo 350
rear end
what all do i have to do to run a 4th gen rear end in a 82 third gen i heard its not hard any info will help
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's a direct bolt in except it's about 2" wider on each side so your stock third gen wheels will stick out.
Car: 86 t/a
Engine: 383 sbc on nitrous
Transmission: Th350 with trans brake
Axle/Gears: 9in ford
not to hijack but most guys seems they run a 15x8 with 4.5 bs on a stock rear so on a 4th gen would you just add 2in of bs to the wheels so it would be 6.5?
Car: 89 RS
Transmission: TH350
Its a direct bolt in, other than E-Brake cables hookup a little different, they are a little bit shorter on the 4th gen rear. I got mine to work so its not really a big deal. And... if your 3rd gen has drum brakes and the 4th gen has discs, then you will have to get a different porportioning valve, one for 4 wheel discs. And I believe the 4th gen is 2in. wider all together, so 1in. each side. Get some wheels with a 5.5in. backspacing.
I think that is it. Good luck.
Car: 87 IROC L98
You can use fourth gen rims or an aftermarket rim with the proper backspacing to correct for the wider housing.
Car: 86 t/a
im trying to make shur i get the right bs for my aftermarket wheels before i go drop the 600bucks and they dont sit right, and i heard it was about 2in per side so 4in widermm better go make shur
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
