B&M Shifter
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
B&M Shifter
Whats up people, Just wondering what everyone think about where and how i put my B&M Shifter in.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Quite innovative, I would say.
But, I would think that small shifter **** would play havoc on your right palm. . .
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
very nice! looks super clean and professional and still has easy access.
though the plate at the bottom of the shifter is innacurate.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
did the reverse shift indicator come with that shifter? ..LOOKs KilLer!! hope mine will come out that nice when I do it
Engine: 7.0L
Originally Posted by BT283
Its is for a reverse valvebody
Car: ford f-150, 2004 suzuki gsxr 750
Engine: 400
Transmission: 400
Axle/Gears: ford 9 inch
can we be honist?
ummmm. not to be a dickk, but, great idea but kinda doesnt look good. to much of to see inside the stock center. but over all good idea and good luck with whatever you decide to go with.
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
I would raise it up some. notch out the plastic console cover. I have a cheetah turbo action shifter, mounted it to the floor and spaced it up just right to be flush with the top of the console, then notched out the cover to fight right around it.
it is raised up as far as it is going to go. the red pointer for the gear selector already scrubs the console. And you really cant see inside of the console. Best way i have found to mount a shifter so far without going with a megashifter
