Just installed Comp engineering universal swaybar - pic inside.
Well figured it was much better than paying $450+, so I bought the universal
from comp.. Decent piece, need to make own mounts but every thing else is supplied.
I mounted it backward as that was easiest, and welded to shock mounts - figured that was better than welding to axle tube and risk warping..
Can get more pics if anyone needs, camera went dead after this one.
So, Tom, it was not that bad of an install, except for making the brackets? I was looking at the C/E one as well, considering the price over the Wolfe Racecraft one. I do have a friend that is a great welder. C/E has a universal one, and one for Mustangs. Those Darn Mustang guys have it so easy...LOL More pics would be great. Do you see any fit problems with a complete Mufflex 4" system, with the C/E swaybar? I saw on Wolfes website, that theirs will fit with big exhaust systems.
Got your pm, thanks! and was looking at you cardomain site - that car is awsome man!
I love the look - really clean!
If you mount it like mine is, there will be no problem at all with the mufflex.
yeah the mustang and LSI guys both have it easy..
Thanks for the kind words, and the reply. If you have a few more pics, I'd like to see them.
You gotta get the VB garage set up with your new toy. I checked it out, but I figured you did not have the time to get any info or pics up yet.
I will try and get pics tomorrow morning after work, gotta go to work now night shift 6p-6a.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
lookin good man. what rear is that? couldnt you fab up mounts to make stock thirdgen sway bars work?
either way it still works and looks good!
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
I used the Spohn rear drag sway bar. Bolted right up to chassis where the old sway bar brackets were on the top side. Works nicely. http://www.spohn.net/product.cfm?productid=1437
Its a moser 9" and its really, really heavy.
I could have easily put a stock one on, but they are not nearly strong enough
to keep car level.. I use stocker on the T/A, and its not up to par by any means.
Looks like they are having BIKER day on Friday - grr
But sat. has been changed to regular racing but no points, so I will be there
and hope to be running well...
Been having problem with car breaking up real bad, found fuel filter to be about 50% clogged - hope that was it..
Tried to test it up the road but not enough room..
BAD406, Looks like your bar is working well and I was close to buying that one - I just saw an opportunity to save $120 and get a more ridgid bar I hope..
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
wow, lookin' great brother!
i'm REALLY cheap and will be upgrading my puney stock 19mm for a ws6 24mm one if i can ever find one. i'll be putting poly bushings on the rearend for it and i've already got poly bushings on the endlinks. hopefully it'll be strong enough for what i'm doing...
Car: 89 Iroc-z
Transmission: TH400
Engine: 7.0L
hey if anyone can come up with one for super cheap and your willing to ship it to GA, let me know!
Will get better after I can take tranny out - car on ground with jack holding trans up.
84z96L31vortec
08-20-2017 12:16 AM
