Cam ideas for 360
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Cam ideas for 360
Trying to decide what cam to put in my 360, has flat top pistons, will be using heads that are either 1.94 or 2.02 (unsure yet) If i run the 1.94 they will have ~58cc chambers the 2.02 will be ~64 cc. The intake is a weiand 7546 xcelerator wiht a 650 dp, 3500 stall and 3.73 gears. Any ideas?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
did you give up on the 305?
i would go with a solid cam similar to my crane powermax cam. 238*/248*@.050 .480"/.500" on a 114 lsa...this cam would straight LOVE the n2o...
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Me and the 305 weren't seeing eye to eye, so rather than make little chunks out of it, i am going to sell it off. I actually got some good info out of it about my chassis. That was the main point of this engine, I should have kept the 305 that I was running last year, but a friend was wanting to put it into his s10 so i sold it off to finance some other projects. I should have took a little more time with this 305 build, but was in too much of a hurry That will teach me. At least the 360 is a 4 bolt bottom end, just came back from being cleaned today, tomorrow i will finish honing it, and get ready to start the build up. Just curious matt what heads did you say that you were running on yours? I like the cam idea thanks. For anyone else who doesn't know the car is STRICTLY a race car. (Well right now more like an expensive garage decoration)
Engine: 7.0L
113 casting aluminum vette heads with the stock 1.94/1.5 valve combo. i put a fresh 3 angle valve job on them and a back cut on the valves. i also cleaned up the bowls and did a little blending. also polished the chambers.
junkcltr
08-02-2019 11:12 PM
Fronzizzle
03-18-2019 08:29 PM
