got a new cam.
Car: 87 gta
got a new cam.
here are the #'s i believe it will go good with my set-up please any feed back appreciated. i will be installing cc 1.52 rr at the same time.
211257/265 for ISKY CAMS .
# Grind No./Type RR-257/265 HYDRAULIC ROLLER Excellent performance cam with good vacuum good idle. 3.08-3.73 axle ratio. 9.5
# 1 compr. Up to 650 CFM Carb. Computer compatible. Stock converter. RPM-Range
# 1400-5600 Valve Lift - INT
# .465 EXT
# .485 Valve Lash Hot - INT
# .000 EXT
# .000 ADV Duration - INT
# 257° EXT
# 265° .050 Duration - INT
# 209° EXT
# 217° Lobe Center
# 112°
# .465 EXT
# .000 EXT
# 257° EXT
# 209° EXT
# 217° Lobe Center
# 112°
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why not go for a Comp Cams XR269HR (PN 08-502-8)? It looks like a better choice for what you're running... you'd get more out of your combo with it. Its just a little bit bigger than what you've got in your post.
Hyd Roller - Good for TPI 305/350 with upgraded exhaust. Needs programmer.
1500-5500rpm
Intake - 269* (218* @ .050")
Exhaust - 276* (224* @ .050")
Intake - .495" lift
Exhaust - .503" lift
LSA - 112*
1500-5500rpm
Intake - .495" lift
LSA - 112*
Car: 87 gta
the cam came from a donar car i got really cheap. so yes i'm happy with it opinion is appreciated though.
if i was gonna buy one i might have gone slightly bigger but with stock heads and 1.52 rollers i think a 500 lift area gets a little scary with stock heads.
1 Post
Ahh, I didn't see that you already had it... yes, that would be a pretty nice cam to use if you already have it
86White_T/A305
09-21-2015 05:28 PM
