11.60's GTA on juice!!
Car: 1991 GTA Convertible
I finally got to the track last night. It was the first time this year so I was a little shakey.l I got there late so I was only able to get one pass in. I juiced off the line and hooked great and shifted perfectly. The only thing that got me was that the trans shifted into overdrive around the 1,000 ft. mark. I thought I was still it D. I shifted it back down to 3rd and the car began to pull hard again. I figure that cost me a couple of tenths and MPH's. If I could remember to keep this thing in Drive I hope to get into the low 11.2-11.3 range. You guys are gonna love this..........I was up against a Mustang GT and check it his time
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Quick calculations say you should have been in the 11.4 range based on 1/8 mile and 1000' mark ET's.
Car: 1991 Chevrolet Camaro
Engine: GM 5.7L H.O. 350HP
Transmission: Rebuilt 700r4/Shift Kit/Servo
You are lucky that your car is well setup, he killed you on reaction time. Get a few good runs in and that alone could cut you to 11.10.
Sorry, didn't realize it wasn't for that type of competition.
But still .097 is pretty good, being is a good driver is sometimes more important than having a fast car.
By the way, congrats.
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Originally Posted by KWIK84
i don't think he bracket races much!!!
obviously
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
They just look lost going around in circles all day, while the rest of us drive straight to the finish line!!! Besides I get dizzy way to easy
Car: '82 Z28
I think a road course would be fun as hell but just making left turns would be boring to me. Kinda like to mix it up a bit It's also fun having to work the steering wheel while trying to go in a straight line weeeeee
Thanks for the replies guys.
EvilCartman, it's a 150 wet shot with NOS's plate set up #5151.......not the greatest but it sure was easy to install.
Yeah, I know my reaction time sucked but I'm leaving the line on a foot brake. I was trying to load the converter but the car started moving forward. On the tree I ran deep and when I saw that I lifted off the throttle and by the time I got back on the tree was at the third yellow. I'm thinking of a trans brake sometime in the future?? Anyone have experience with this on a 700R4?
Car: '82 Z28
Yup, I was cutting .03x lights all night one night. Still not wonderfull but they were the best lights I've cut so far.
Yeah I've got a B&M WOT 3-4 upshift valve.
I'll need some more practice at the tree. Don't think I'll get a trans "break" for the Level Ten 700R4, oops I meant trans brake.
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Originally Posted by chikn305
Slightly off topic, but I see you're talking about t-brakes. Where can you get one for the 700. I need to get one for my new combo.
Art Carr - Product Detail</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<meta name="description" content="Art Carr Performance Products high performance transmissions and torque converters have been redesigned and highly profiled to handle the high horsepower of today's engines. Entering our fourth decade of performance, Art Carr Performance Products still leads the field with a vast product line of leading edge components and over 2500 part numbers in our current catalog.">
<meta name="keywords" content="high performance transmissions, valve body, torque converters, shifters, art car, transmisions, valve bodies, Chevrolet, Chrysler, Ford">
<meta http-equiv="Content-Language" content="EN">
<meta name="author" content="WE LOVE TEXAS">
<meta name="distribution" content="Global">
<meta name="copyright" content="© Art Carr">
<meta http-equiv="Pragma" content="no-cache">
<meta http-equiv="Cache-Control" content="no-cache">
<meta name="robots" content="FOLLOW,INDEX">
<style type="text/css">
a:link { color: #0000FF; text-decoration: Underline; background: Transparent; font: normal 10pt Arial, Helvetica, sans-serif}
a:visited { color: #990099; text-decoration: Underline; background: Transparent; font: normal 10pt Arial, Helvetica, sans-serif}
a:hover { color: #0000FF; text-decoration: None; background: Transparent; font: normal 10pt Arial, Helvetica, sans-serif}
a:active { color: #990099; text-decoration: Underline; background: Transparent; font: normal 10pt Arial, Helvetica, sans-serif}
a.afooter:link { color: #0000FF; text-decoration: Underline; background: Transparent; font: normal 8pt Arial, Helvetica, sans-serif}
a.afooter:visited { color: #990099; text-decoration: Underline; background: Transparent; font: normal 8pt Arial, Helvetica, sans-serif}
a.afooter:hover { color: #0000FF; text-decoration: None; background: Transparent; font: normal 8pt Arial, Helvetica, sans-serif}
a.afooter:active { color: #990099; text-decoration: Underline; background: Transparent; font: normal 8pt Arial, Helvetica, sans-serif}
h1 { font: Bold 20pt Arial, Helvetica, sans-serif; color: #000000}
h2 { font: Bold 14pt Arial, Helvetica, sans-serif; color: #000000}
p { font: Normal 10pt Arial, Helvetica, sans-serif; color: #000000}
li { font: Normal 10pt Arial, Helvetica, sans-serif; color: #000000}
p.pfooter { font: Normal 8pt Arial, Helvetica, sans-serif; color: #000000}
</style>
<script language="JavaScript">
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function YY_checkform() { //v4.07
//copyright (c)1998,2001 Yaromat.com
var args = YY_checkform.arguments,myDot=true,myV='',myErr='',addErr=false,myReq,rx,myObj1,myMa,myAt;
for (var i=1; i<args.length;i=i+4){
if (args[i+1].charAt(0)=='#'){myReq=true; args[i+1]=args[i+1].substring(1);}else{myReq=false}
var myObj = MM_findObj(args[i].replace(/\[\d+\]/ig,""));myV=myObj.value;
if (myObj.type=='text'||myObj.type=='password'){
if (myReq&&myObj.value.length==0)addErr=true;
if ((myV.length>0)&&(args[i+2]==1)){ //fromto
if (!(myV/1)||myV<args[i+1].split('_')[0]/1||myV > args[i+1].split('_')[1]/1){addErr=true}
if ((myV.length>0)&&(args[i+2]==2)){ // email
rx=new RegExp("^[\\w\.=-]+@[\\w\\.-]+\\.[a-z]{2,4}$");if(!rx.test(myV))addErr=true;
if ((myV.length>0)&&(args[i+2]==3)){ // date
myMa=args[i+1].split("#");myAt=myV.match(myMa[0]);
if(myAt){
var myD=(myAt[myMa[1]])?myAt[myMa[1]]:1; var myM=myAt[myMa[2]]-1; var myY=myAt[myMa[3]];
var myDate=new Date(myY,myM,myD);
if(myDate.getFullYear()!=myY||myDate.getDate()!=myD||myDate.getMonth()!=myM){addErr=true};
}else{addErr=true}
if ((myV.length>0)&&(args[i+2]==4)){myMa=args[i+1].split("#");myAt=myV.match(myMa[0]);if(!myAt)addErr=true}// time
if (myV.length>0&&args[i+2]==5){ // check this 2
var myObj1 = MM_findObj(args[i+1].replace(/\[\d+\]/ig,""));
if(myObj1.length)myObj1=myObj1[args[i+1].replace(/(.*\[)|(\].*)/ig,"")];
if(!myObj1.checked)addErr=true;
if (myV.length>0&&args[i+2]==6){myObj1=MM_findObj(args[i+1]);if(myV!=myObj1.value)addErr=true;}// the same
}else
if (!myObj.type&&myObj.length>0&&myObj[0].type=='radio'){
var myTest = args[i].match(/(.*)\[(\d+)\].*/i);
var myObj1=(myObj.length>1)?myObj[myTest[2]]:myObj;
if (args[i+2]==1&&myObj1&&myObj1.checked&&MM_findObj(args[i+1]).value.length/1==0){addErr=true}
if (args[i+2]==2){
var myDot=false;
for(var j=0;j<myObj.length;j++){myDot=myDot||myObj[j].checked}
if(!myDot){myErr+='* ' +args[i+3]+'\n'}
}else
if (myObj.type=='checkbox'){
if(args[i+2]==1&&myObj.checked==false){addErr=true}
if(args[i+2]==2&&myObj.checked&&MM_findObj(args[i+1]).value.length/1==0){addErr=true}
}else
if (myObj.type=='select-one'||myObj.type=='select-multiple'){
if(args[i+2]==1&&myObj.selectedIndex/1==0){addErr=true}
}else
if (myObj.type=='textarea'){
if(myV.length<args[i+1]){addErr=true}
if (addErr){myErr+='* '+args[i+3]+'\n'; addErr=false}
if (myErr!=''){alert('The required information is incomplete or contains errors:\t\t\t\t\t\n\n'+myErr)}
document.MM_returnValue = (myErr=='');
</script>
<SCRIPT LANGUAGE="JavaScript">
<!-- Begin
function WeLoveTexas(img)
foto1= new Image();
foto1.src=(img);
Controlla(img);
function Controlla(img){
if((foto1.width!=0)&&(foto1.height!=0)){
viewFoto(img);
else{
funzione="Controlla('"+img+"')";
intervallo=setTimeout(funzione,20);
function viewFoto(img){
largh=foto1.width;
altez=foto1.height;
stringa="width="+largh+",height="+altez;
newWindow = window.open("vwd_justso.htm","newWindow",stringa);
newWindow.document.open();
newWindow.document.write('<html><title>Click to Close
http://www.artcarr.com/instructions/17030.pdf
If anyone gets one, Let us all know if it works.
Jerry
FASTBIRD, Thanks! I see that you're from N. Plainfield. I live in Bound Brook, like 10 mins away from you down 22. You have a 11 firebird? Not to many people around here have 11 second street cars. The ricers around here get h@rd on's when they run 14's. PM me. later!
Joe
Joe
