5 point harness assembly
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Just recently picked up some 5 point harnesses from RCI. I can't for the life of me figure out how to put all the pieces into that center clip. I don't have the cam-lock style, anyone have some pics, maybe could even do piece by piece, especially since they came with no instructions
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
For your harness it goes left side with the tab, then left shoulder slid over tab, crotch strap over tab, then right shoulder, then the buckle, at least that is how my RJS is set up, should be the same for the RCI though. Make sure that when you are setting in the seat and pull the shoulder harness over that the tabs should come close together, not far away. Hope that makes sense to you, I will check, but I don't think that I have any pictures of the harness all buckeld together.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I always do mine up:
Grab the left side strap (without the buckle). Then left shoulder strap, right shoulder strap, crotch belt. All these are now on the left side strap. It then feeds into the buckle on the right side.
Night rider327
09-02-2015 04:17 AM
