build me a 355 combo please.
here's what i'm looking at building:
350 4 bolt main block
forged TRW pistons, ARP bolts throughout.
solid lifter cam 250ish/.550 lift
3600 stall'd TH350
4.11 geared 9"
28" slicks.
dart iron eagle platinum 200cc heads or similar price-wise.
750 DP holley/ performer RPM or vic JR intake
possible 150-200 HP shot as well.
what I'm trying to figure out is cam selection and head choice, streetability not that important as it's not driven often at all. Any ideas? thoughts on what it should run?
3600 stall'd TH350
4.11 geared 9"
28" slicks.
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Well what are your exact intentions with this motor? Street only, street/strip or strip only? What powerband did you want to make power in?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
are you bent on a 355 or would you consider getting a stroker crank and make it a 383? if sticking with the 355, get heads with at LEAST 200cc intake runners or higher if your pockets permit (preferrably aluminum). With the good flowing heads and the cam specs you listed you'll be able to "use" the victor jr. and also, nitrous LOVES a good breathing motor especially on the exhaust side just like any other method of forced induction.
P.S- with nitrous in mind, get a dual pattern cam with at least 10* more duration on the exh. side.
1 Post
Car: 1989 Iroc Z L98
You could probably even go with a 4000 or 4500 converter with 250* @ .050.
If you buy a set of Dart heads, keep in mind that they need a lot of port work to flow decent. My Dart R series 220cc heads needed a lot of work to flow in the 300cfm range @.050.
i would stick with the 355 and put a set of AFR 210's on the motor. I got a screaming deal on my Dart heads, and after buying offset rockers, special guideplates and paying for port work, I wish I would have just purchased an "out of the box" kick *** head like an AFR.
Are you thinking solid flat tappet or solid roller?
With a 350 and a 3600 converter, I would go with the XS282 from comp. It specs 244/252 @ .050 and .520/.540 lift (assuming you are going flat tappet).
With a 350 and a solid roller camshaft, I would go with the XR280R.
If you can't tell, I like the Comp XE line of camshafts. Just don't overcam it if you do go 350ci.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I have done two of these combos together using the trw 2256 flat top pistons. and 200cc dart heads I used the comp 294s in one engine and a vic jr intake it ran 12.00 on motor and 10.70 on a 175hp tune of nitrous. The other motor I had basicly the same cam but I had it custom ground from comp and put it on a 106 lobe sep instead of there 110 lobe sep this motor also had the lighter trw flat tops.We also used a rpm air gap intake. It ran 11.7 on motor and 10.20 on a 200hp tune of nitrous I used a single patern cam because the heads after some work flowed like 250 in and 190 or 200 on the ex.
1 Post
Originally posted by xpndbl3
ross how much head work was done to them? ever tried them out of the box and ran them that way? i'm wondering because the new iron eagle platinum's are supposed to flow 10% more than the older casting, would that flow similar to your worked heads?
Car: 82 camaro
Engine: 434 ci
Transmission: t400
With the dart heads I find the newer castings are better than the old stuff ie:94-95 castings. I would think with some pocket porting and a good valve job with a 30 deg back cut you will be very close. I forgot the motor with the 106 lobe sep also ran a 1.6 rocker arms.And both motors were zero decked.
Car: 88 Camaro
Engine: 355
Transmission: TH-350
My combo is very similar to the one you are looking for....
I have ran a best so far only got it to the track 3 times, but anyway it went 12.1@111...
This a 355 w/older Dart iron eagle 200's w/ no work 4.30, 28" tire and a 4,000 + stall....I was goin thru the traps @ roughly 6100...
Hope this helps..
Hope this helps..
1 Post
You can do mid-low 12's cheaper and more streetable. If you are purchasing aftermarket heads and running a solid camshaft, I wouldn't settle for less than 11.5's.
A 350HO crate engine, mildly ported vortec heads, 9.9:1 compression, XE274 hydraulic flat tappet camshaft, super victor for vortecs intake, Speed Demon 750 cfm carb, hughes 3000 stall and street tires bested me 12.28 @ 111.85
Something to think about.
unknown host.....I agree with the vortec combo and I have used one in the past with my buddies. But they don't use nitrous all that well. Typically the ET drop from a 75 shot up to 200 shot doesn't take off much ET that makes them not as worthwhile as aftermarket heads with bigger runners. Plus the cost of vortec heads plus machining for bigger springs, screw in studs, and the guides cut down, and a vortec intake, is very close in cost to a set of Dart Iron Eagle heads and a victor Jr intake, which would still get me quicker times than vortec heads comparing to the combos above me. I'm really looking for high 10s on spray and high 11s on motor. I'm hoping the Dart heads combo would take me there the cheapest.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
xpndbl3 I think high tens will be well with in range. I also think vortec heads with the machine work and a little help on the ex side will do the combo you want also. I have seen stock vortecs flow 220-230 intake side and i think the ex flows like 170s but like you said the intake and machine work add alot to the cost.I helped a kid out that had a very limited budget with a discount auto long block sold the heads off of it put a set of vortecs and 1.6 ratio rockers and performer int the car ran 13.00s on motor with stock cam and 11.9 on a 150hp sniper kit.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
You'll make those times, no problem. On a side note the dart heads are much more forgiving if you overheat the motor. Good luck
1 Post
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
355
fuel inj. HSR
protopline 200cc
comp 306 230/244 w/ 1.6r
4.11's and 26" tire
T-56
on a nitrous tune went the time in my sig n/a.
fuel inj. HSR
protopline 200cc
4.11's and 26" tire
T-56
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
My combo
Heads W/P II 200cc - 61cc after a .0018 flat mill (calculated guess)
355ci with hypers .125" domes (H617?? I think) - stock crank & rods
4.10 gears - 26" x 8.5 x 15 - approx 4000 stall converter TCI 10"
times in sig - N/A 12.0.. - so far 11.1 with 210 hp NOS plate lifting off near end of pass
Cam is a Crower solid 00355 - 106 * grind - 244/250
Hope this helps
Hope this helps
1 Post
Originally posted by caribbean 85
My combo
Hope this helps
My combo
Hope this helps
so i ended up picking up a pair of vortec heads this week for an extremely cheap price. i know the XE274 is a proven combo for those heads, but would running a comp 294S or the XS282, etc. net me more power? i'm thinking a smallish solid cam might net me some more power. Any ideas? really looking for every bit i can get out of it.
wow, we can no longer edit threads......sooooo I'll add it here, this cam will also be used for a 150-200 shot of nitrous as well, sometimes down the track after I get the best N/A motor times out of it. So maybe a N/A cam and a more nitrous orientated cam would have to be chosen.
Engine: 383ci chevy
You are running 210 horsepower jetting on a stock rod, stock crank, hyp. piston engine? Which kit are you running? If it is an NOS Cheater, your saving grace might be that the cheater plate seems to go rich past the 180 setting.
I swapped out my existing Cheater plate for a Big Shot "upgrade plate kit" a nice kit with jets, braided lines and fittings for a clean swap
Jets included begin at 82/91 - which is 210hp for Big Shot plate -
I use dedicated Blue pump and lines for NOS system - running between 6 1/2 and 7 psi on the fuel press. gauge when system flowing and I have a fuel pressure safety switch and full throttle activation switch
The Solenoids are my Cheater system solenoids
Important - flowing the fuel system through plate with jets installed "off the engine" helps to avoid fuel pressure issues
A must for proper verification of actual flowing fuel pressure during activation - revealed alot to me about trusting (or not trusting) my fuel gauge's apparently high pressure reading when using a deadhead regulator system like the Holley Blue pump
After all this - its all when you hit the button
how much are u looking to spend on this whole deal? I'm sellin my pump gas 383, it'll run high 10s on motor with the right combo and high 9s on nitrous.. totaly streetable, idels at 900rpm, no surging, no problems, very fun And u cant beat teh price i'm selling it for.. $6500 for a potential 9 second bullet, i paid $11k when i built it fresh, also comes with lightweight power steering pump, GM chrome alternator, etc.. ready to rumble.. all u need is a carb for it..
383ci, 4 bolt GM 010
Lunati Pro Mod Forged Crank, Pistons, and Rods
Solid Roller cam
AFR 210cc heads, CNC ported
Edelbrock Vic Jr.
MSD Billet Distr.
MSD Wires
Comp Billet Timing set
Fluidamper balancer
Crane Gold series race 1.6 rockers
Crower Stud Girdle
ARP everything! head studs, main studs, everything
Cast Aluminum 'Chevrolet' valve covers
I will take pics tomorrow... Look at my sig, u can be doing this NA :tup: Motor is just beggin for nitrous
MJ
Solid Roller cam
Edelbrock Vic Jr.
MSD Billet Distr.
MSD Wires
Fluidamper balancer
Crower Stud Girdle
MJ
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Call comp cams ask for a 294s cam made with a 106 lobe sep. add 1.6 rockers and have some fun.
1 Post
any cam help on my post above?
With a set of vortec heads, I think it would be important to keep your lift down. Also, pick a camshaft for the motor, not for nitrous . You can always pill it up later .
I think your best bet is to stay at or under .500 lift with duration in the 24X/24X range.
Hm, this tight lash comp solid grind looks really sweet!:
12-501-5
242/246@.050, .510/.520 before last, 106*LSA
i was thinking the XS 282, it's 244/252 with .520/.540 lift looks like a tight lash at .016/.016 on a 110 lobe sep. which is one size larger than what you recommended, might be a little too large?
Your choice is similar to the XS274, which is one size smaller. Do you think the 106 sep. is a better idea than 110? I just always see people run the XE274 with 1.6 rockers, which i figured was the same thing as the XS282 essentially for lift, etc.
Let me know on the 110 vs 106 and the other cam I picked out. I definately don't want to go too high, the compression would probably be 9.5 to 10:1 since the block has been decked a little it looks like and the heads are factory. I'm not worried about running premium through it, but 100 octane would be a little pricey.
I also noticed that cam is not sold as a cam and lifter kit so which solid lifters would I want to run? CCA-813-16? or CCA-833-16? one is $96 and the other is $86, plus the cam is $155 so that would be around $250 for the cam, whereas my pick was $233 for cam and lifter kit, but if the 106 lobe is better, then I'll run that one. Thanks for the help guys.
Car: 82 camaro
Engine: 434 ci
Transmission: t400
I like the Howards soild lifters with the oiling hole at the bottom helps prevent cam failure. Or at least I think it does. And thay do cost a bit more.
Car: Z/28
Engine: 355
Transmission: Turbo 400
Im using a Engle custom ground solid cam in my 355. Specs .548/.564 lift 261*/266* @ .050 on 106 LC. Made 517hp 460 lbs torque At Verbrancic Bros. Dyno in California on 91 pump gas. Its a mean S.O.B. to drive on the street. Idles at 1500 rpm with next to no vacuum for brakes.(Using a canister) Using AFR 195 comp ported heads, 10-1 comp Vic Jr manifold and a 750 Holley
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
xpndble, do you have a stud girdle? if not, i'd look at BTE, it's the cheapest one i've ever seen, and a nice bar/spring setup, not a u-bar. Will help you with a solid cam in the upper range. (hard to beat $59 too).
i'll be running a stud girdle since IHI recommended that one to me as well. I'll have to find the website again that listed those through google or yahoo. I'm ordering the cam this week so I should be able to toss in the short block shortly into the car, as soon as I get my AJE crossmember to line up finally.
Hotrodboba400
12-10-2019 07:07 PM
codeysabatini
11-10-2015 04:07 PM
Billy Decker
09-04-2015 03:46 PM
