strut question
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
strut question
i know this is a suspension topic but i wanted some racers response on this. i just got my tube k member a arms and manual rack and wanted to have everyhting new up front so what kind of struts do you suggest? this car is bascially a track car that has hardley any street time. i might do a sat night here or there but its really just becoming a track car. thanks guys
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Dragstrip only track car I assume.
Cheapest, Lakewood 90/10
Better and a lot more expensive, Koni SPA1
I'm sure there are a few more options as drag race, third gen specific, replacement struts but none of them are going to be cheap.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
i like my tokico adjustable's but for a mostly track car.. they might be too much for ya and you dont need the extra adjustability they provide, as you might never use it. they handle good as they can be set up stiff. and at the strip, the softest setting is good for drags. its just that if you take it out to a show or out for a quick cruise on a weekend, you can set them abit stiffer for a nicer controlled ride on the street
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
theyre on this page. http://cachassisworks.com/vas_produc...istrut_boltins
id give my left nut for them. I am doing a motor swap for my neighbor that would give me more than enough for them.HMMMMMMMM
1992 Trans Am
08-09-2015 04:32 PM
