seem right? drag racing time
Car: 1988 Trans Am GTA Black with Black Cloth Interior
Engine: Supercharged 355 Lingenfelter, TPIS/AFR Heads
Transmission: Street Strip 700 Turbo with 3000 stall converter
hey all jus wanted to see if i got the act together on this car. my car is a 88 gta. was naturally aspirated with 355 tpis/afr 195 heads. acording to tpis they're 50 cc chambers which takes me to 12.5:1. tpis mini ram with cold air intake. zz9 cam from tpis and 1:6 rockers. roughly est. bout 350-375 at flywheel im guessing. according to desk top dyno should be around 425 but i dont believe it. anyways its the 700 turbo with 3000 stall convertor 3.27 rear runnin stock 3760 car weight on drag radials. note: car still has power steering, a/c, etc. and has stage 5 chip also from tpis. hooking up hard i ran 8.87 on the 1/8th. with stock radials somewhat spinning (not bad) i ran 8.63 in 1/8th. and 13.77 1/4 mile.
i think it should of done better but you guys tell me what u think
that was shifting around 5400 rpm....it was still pulling halfway good up to 5800
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Re: seem right? drag racing time
i know it runs fatter than H*LL especially when cold and has fair about of black smoke showin its fat when goin down track. I've tried messn with tps sensor and all to lean it out but i dunno. should i get ahold of someone to custom burn a chip or ??? where should i start? i've been drag racing forever but this efi performance stuff in a newer part of my adventures...im used to enderle mechanical fuel injection
i forgot they did sell me 24 lb/hr injectors for this thing cuz i had one stickn open intermediatly. I see alot guys with em so i dont believe they're too big??? am i right?
i think it should of done better but you guys tell me what u think [/B]
1/4 mile was like 96 i believe....1/8'th i'd have to look for sure but i wanna say it was high 60...i'll look at my slips and post for sure later 2nite
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
96? I'd say fix your gas problem. You should be trapping 105+. imo that cam isn't good for mid-low 12s really, but your setup should carry u into the low 13s maybe high 12s.
im throw'n a supercharger on it here in the next couple months.....procharger 15-20 psi setup
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Your set up should perform better with some 3.70 gears or higher and I think TPIS suggest that you run 3.73 gears anyway. But other than the rich condition you run well into the 12's on slicks and low 13's on street tires.
My old set up was similar with 3.70 and 3500 stall , but I had the ZZ409 cam and I ran 12.4X all day with 1.7X short times. So you need some tuning done.
yea i know...definatly gotta drop my compression. They're claimin i can keep it on pump gas and get a 85%+ hp increase. of course i gotta run an intercooler and relocate the battery and all that junk. i extreamly dout my borg warner 9 bolt will hold up either so i'm planning on converting to a 9 inch ford rear from strange engineering
Car: '72 Chevy Nova
Transmission: TH350
lol yeah it'll snap that 7.75inch ring gear like nothing LOL
i suggest you get your car figured out N/A before you dump boost on it. And make sure to get it dynotuned before you go whomping on it. And I doubt you'll get it to push 20 PSI on 91 octane pump gas.
for that i need someone to burn me a chip then right?
Terrell351
06-13-2021 01:13 PM
