low mount alt.???
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
low mount alt.???
Has anyone found brakets to low mount the factory 105amp alt on the drivers side? If not what other (non-factory) alternatives are there?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I know theres a C-shaped alt bracket out there that basically flips the alt upside down from the stock V-belt location. Puts it right down there with the mechanical fuel pump. I saw it on Ebay a while back and have been considering using one.
Car: 91 firebird
Axle/Gears: 4.30
I really want to mount it on the drivers side. I have mocked up some brackets but i like the prof look.
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I just made up some spacers and a couple of small brackets and mounted it into the front of the drivers head. Pic doesn't show that well but might give you an idea.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
theres one in jegs part number 969-9758 but i dont think it will fit with the factory power sterring or the s-10 box. i am going to this one when i change my k member and do a rack and pinion. hope this helps, sorry if not
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Along this same subject, If anyone has pictures of an alternator mounted while using an electric water pump, could you post them? (IHI I know you've got some ) I dont care if I need to get a new alternator or not, the housing on my last one cracked anyways.
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Re: low mount alt.???
http://www.hotrodlane.cc/
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Moroso sells one. I have it and it works great..
http://www.moroso.com/catalog/catego...?catcode=30001
Car: '82 Trans Am
Transmission: TH475
NBrehm
08-05-2015 07:57 PM
