Fastest NA dual plane car
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
A friend and I were talking the other day and wondered what the fastest naturally aspirated dual plane cars on this site are. I the fastest I can think of might be one of the Vortec/RPM/274 combos in the high 11s.
I was saying that I was going to try swithing to a Vic Jr. this spring but was curious to what others have done with a divided plenum.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I think your combo could be faster as is. 406 w/ 11:1, AFR's, solid roller.... I'd guess closer to low 11.0 instead of 12.0. Sorry to be off topic.
Car: 1976 Camaro LT
Transmission: TH350
there is a guy in my club, NJFBOA, that runs low 11's with a performer rpm and vortec heads. i am not sure what cam he has, the car doesn't ahve much weight reduction either.
we get to cheat a few months out of the year here in jersey, we usually have a month or so of negative DA's at each end of our season
Car: 86 Trans Am
Engine: 406
Originally posted by brutalform
Im sure being in Canada, that he just might be in a high altitude area. Its STILL an 11 second car. And at 3600 lbs, its no lightweight either.
The car does have more in still. I haven't really hung it out yet either. It hasn't really seen much above 6000 rpm.
There is likely a few more mph in it, but the trap speed is a bit high for the ET. I need to get that 60' down and consistant. I think I'll be getting a new TC, swapping intakes, and putting cutouts after the collectors.
Engine: 355
Axle/Gears: 4.11
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
10.5:1 c/r, 200cc dart iron eagle heads, solid lifter cam, holley street dominator dual plane intake, powerglide, 4.56's, 3350lbs., went 11.87.
can't imagine what it would do with a th350...
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
11.53 @ 115.17 best to date at 3315 lbs in J/SA trim. Motor is the 150 hp factory rated 305 using the stock cast iron 055 intake manifold.
Linson
08-21-2015 02:12 PM
