Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
TPI vs LS1
Old 01-26-2006 | 03:42 PM
  #51
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
ohhhh I was going to say. lol
Old 01-26-2006 | 05:35 PM
  #52
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Originally posted by 89IrocZ350TPI
Sorry to get off topic but does anyone know what stall I should get? thanks
With stock cam i would get a 2k stall.
Old 01-26-2006 | 06:18 PM
  #53
Car: ws6
Engine: ls1
Transmission: m6
Anyone know a good brand?
Old 01-26-2006 | 07:56 PM
  #54
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
really good? Vigilante.
Old 01-26-2006 | 07:57 PM
  #55
Car: '72 Chevy Nova
Transmission: TH350
TPI works in strange ways when it comes to gears. I cant figure them out.
gears really won't have much effect on the 60 ft in cars with a good amount of power (300+ rwtq). Gears will help past the first 60 ft.
If anything the gears will make you spin worse in the 60 until you get used to them.
Old 01-26-2006 | 08:00 PM
  #56
Car: ws6
Engine: ls1
Transmission: m6
Ya my car dynoed at 329 rwt. So at the flywheel it proably has alot. Enough to smoke the tires.
Old 01-26-2006 | 08:44 PM
  #57
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Not if you have adequate traction.
Old 01-26-2006 | 09:04 PM
  #58
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Vigilante and Yank both make good torque converters.
Old 01-26-2006 | 09:09 PM
  #59
Car: ws6
Engine: ls1
Transmission: m6
Sounds good. I have heard of Vigilante before. What do they go for around $700?
Old 01-26-2006 | 09:54 PM
  #60
Car: 1989 GTA
Engine: 369 TPI
I have the Yank SS3600 and it was around $700, maybe a little more but sure is worth the money. A Vigilante 3200 is the same as a Yank 3600 from what I have read.
Old 01-26-2006 | 09:58 PM
  #61
Car: ws6
Engine: ls1
Transmission: m6
Do these just help in off the line performance? Or is it all threw the powerband? I have a Camaro book here by david shelby i think it is. Anyways there was an article in there about a car that could chirp the tires. Then once they put a street fighter converter on it the tires would spin all day long.
Old 02-15-2006 | 04:19 PM
  #62
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
Re: TPI vs LS1
Has anyone with a highly modded TPI car beat any LS1's up at the track. If so list mods thanks. Cant be too many lol
TRAXION's car had an aftermarket TPI system like HSR or SuperRam (if you'd consider that "highly modded TPI") along with many other mods (AFRs, cam, etc.) on the stock L98 block, and I'm quite confident his vehicle would have obliterated many stock LS1s. He was running like 11.6s.
Old 02-15-2006 | 04:25 PM
  #63
Car: 1989 IROC
Engine: LB9
You know what I cannot understand about L98 cars. I have an article here that has the 87 L98 rated as a 14.5@95 in the 1/4. I have another one that says 15.2@91. Are some test tracks in better shape than others lol. can someone explain this cause I cant. An L98 that runs 15.2 stock is not going to be able to take any ls1 with just bolt-ons.
The answer lies in the fact that the retards who work for the magazines didn't know how to launch the car. I see the same thing with magazine compros of modern cars, where they're running much slower in the article than you'll see an experienced driver run with one. If they'd printed the 60' time with their 1/4 time, you'd probably see the discrepency.
Old 02-22-2006 | 04:11 PM
  #64
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
What your car needs is a mild cam, 2400-2800 stall, Good tires, or even slicks, shift kit helps, start thinking about heads.
Cam: Comp Cams, not going to list specs because I don't know how you drive the car and I don't know what heads your running
Stall: Yank is one of the best in the market. Stay away from B&M
Tires:BFG T/A's
Shift Kit: All brands work well, I used TCI
Heads: Trickflows, AFR, World, stay away from Edelbrock, they are ok heads, but for the price they arent the best value.
Old 02-22-2006 | 04:13 PM
  #65
I can vouche for that. Even STOCK my car run faster than 15.2. First time out it ran 14.66 at 94 mph.
Now runs about 14 flat when it's running right.
Old 02-22-2006 | 04:14 PM
  #66
Car: ws6
Engine: ls1
Transmission: m6
14.0? What mods?
Orr89RocZ
04-25-2016 08:28 AM
lt1z350
Brakes
09-12-2015 09:28 PM
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: TPI vs LS1
