what size backspacing??
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
didnt know where to put this so i decided here is fine for now. i was wondering what size backspacking would i need to fix some 17x11's (w/ 335/35 tires) in the wheel wells and not have 2 worry about rubbing. im debating now if i wanna tub or not becuase the 11.5" slicks i use now on my 15" rims are really close 2 rubbing.
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
I run 5.5" bs on my car with 15x8 prostars with 28x11.50 et streets and it fit with slight modifications to the inner fender and cutting the bump stop. Im not sure if you could get away with anything more than 5.5".
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
same here, 5.5" BS on my 10" rims with same mods to get tires not to rub.
Car: 90 formula
Transmission: 700-r4
Thanks.
Car: 1987 Trans am
Engine: Cammin Ls1
I was actually refering to the rears. There is a rear bumpstop that is on the inner fender that sits just above the axel tube behind the tire. I was running this setup with out it removed and was fine, i just felt the clearences were just to close and its mainly a track car so i cut them off. I did need to massage the inner fenders towards the front and back of the tire. In the rear im running a 5x8 with 5.5bs with a mt et streets 28x11.5 and in the front im running 15x3 with 1.75b.s with mt sportsman pro 26x6. Here is some pics to help out
1.
1.
Pac J
05-17-2020 10:44 AM
