What would this set up run?
1 Post
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I am going down to look at a fellow thirdgenners iroc this weekend and was wondering if anybody had an idea of what the setup on the car would run in the 1/4 and how much hp it should lay down.
IROC Z-28, 350 TPI V-8, world class t-5 Transmission, Newer 10 Bolt Rear End
motor upgrades
350 roller motor installed at 95 k 20k or so on new motor set up
zz9 cam
1.5 crane gold roller rockers
black crinkle chevy bowtie center bolt valve covers
afr 195 heads
tpis big mouth intake
tpis large tube runners
52mm throttle body
24 accel injectors
tpis adjustable fuel pressure regulator
tpis ported plenum
slp 1 3/4 headers
msd6a ignition box
msd billet distributor
msd blaster coil
taylor wires
bosh 4 plugs
k&n filters
cold air or ram air boxes
tpis stage 5 chip
160 thermostat
alumnuim driveshaft
3.23 gears posi
motor upgrades
zz9 cam
afr 195 heads
52mm throttle body
24 accel injectors
tpis ported plenum
slp 1 3/4 headers
msd6a ignition box
msd blaster coil
taylor wires
bosh 4 plugs
k&n filters
tpis stage 5 chip
160 thermostat
alumnuim driveshaft
3.23 gears posi
Car: ws6
Engine: ls1
Transmission: m6
There are so many of these threads lol. A 350 TPI with those mods should put down mid-high 12's with traction. Id plan on high 12's though.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: What would this set up run?
Seriously, I doubt you're going to see 12's. Not enough gear, and probably not enough traction with the gears you have.
Car: ws6
Engine: ls1
Transmission: m6
I think it will depend on the tune of the car. I am going to say high 12's beacuse I am running 13.5's on my 350 with just bolt ons. Think about it he has bolt ons plus heads,cam, ect.
I forgot about those.....With black crinkle chevy bowtie center bolt valve covers you may see 11's
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
ET will also depend on where you race. What's the elevation of the closest track to Lake tahoe? A high altitude track will slow you down. My guess is that you'll go to Top Gun Raceway in Nevada. They list the elevation at 4000 feet. That's going to be pretty high when you factor in the density altitude. If someone says you should run high 12's, don't be disappointed if you only get mid 13's.
Car: 1991 Camaro B4C
Engine: L98 350 cid (5.7L) TPI v8
Transmission: 700 R4 auto trans
Axle/Gears: 10 bolt w/girdle & 3.42 MotiveGears
I was just curious... how did the IROC- Z Camaro perform at Sacramento raceway?
Fast355
12-02-2016 06:33 PM
