Biggest Nitrous Shot
1 Post
Car: 2001 SS
Engine: bolt on LS1
Does anyone know what the biggest shot you can run without having forged internals becuase the forged stuff is twice as much 125?150?200?
Thanx for the help!!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For a V8, 125 is relatively safe. By 150 you start risking damage more in hammering out rod bearings. As far as I'm concerned, anything above 150 should have a forged bottom end.
I ran 160 hp shot on my stock bottom end all last season. I ran every weekend. I also sprayed 200 the last two weekends of the season, but I wouldn't recomend that large of a shot i only did it because I knew I was going to be pulling the engine after the season. When i tore the engine done however I was totally shocked at how good everything looked. Anyway if you're looking for reliabilty I wouldn't go over a 125.
1 Post
Car: 2001 SS
Engine: bolt on LS1
Im not talkin about stock its 5140 Steel SIR lightweight rods, std/std cast crank, KB Hypereutic pistons ist a complete rotating assembly from Eagle.
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
^^ what he said . ring gap ! when i was spraying a 350 shot i had the ring gaps out to .030". i broke 7 pistons spraying 300 on .020" ring gap.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Contact the ring manufacturer, if it's the stock rings/pistons, then run it on the rich side w/ conservative timing.
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
150 shot
on my tpi a 150 wet shot has been totally safe. i don't even retard the timing or switch the PROMS... Im on my 27th bottle fill now, which is about 135 1/4 mile runs of juicing without any side effects. My motor is untouched internally and 149,000 miles old. i got the whole history on my cardomain site.....
i beat this car alot too...
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
dbrochard
09-25-2015 04:56 PM
