1/4 estimates
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
1/4 estimates
Just another 'what will I run post'
87 L98
700r4
3.27/posi
Falken 705's (sticky *** street tires)
Fresh Auto w/shift kit, servo
Ported SLP runners
Port matched plenum/base
AFPR 49 psi
Magnaflow catback
Hollow cat
Full MSD ignition, wires, distributor, coil, ect
race weight 3550 including driver
87 L98
700r4
3.27/posi
Ported SLP runners
AFPR 49 psi
Magnaflow catback
Hollow cat
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
its beggin for headers and stall.
i think you COULD break a high 13 on a great launch, but low 14's would be the norm for now without the stall and headers
and if you havent, gut your airbox by cuttin out the bottoms of where the filters sit. but leave the center bar section for filter support.
Car: ws6
Engine: ls1
Transmission: m6
14.2's id say. Next your going to need headers, and a better intake manifold. BTW on your web site it says u have tb bypass and a hypertech chip....i guess u forgot to list a few things.
Edit:
I also have gutted the airboxes
TB Bypass (if it matters)
It has a mail order chip in it aswell. I believe hypertech.
I plan on headers, prob some hooker 2055's since I can't afford SLP's, although I would like some 1 3/4.
I'm not sure on the stall converter though. How hard is the install. I could possibly put it in at school where I have access to a lift and trans. jack. Is it possible to unbolt the tranny while leaving the driveshaft on, sliding it over on the jack, put on the stall, prep it with all the fluids first and all, then bolting the tranny back up?
Originally posted by 89IrocZ350TPI
I say with headers and a better intake you will see high 13's
Ya, if you get those mods youd probably run the same times as me.
Btw, ur car is sweet. I don't much care for those hoods, but on your car it looks nice.
put all the stock intake stuff back on, add a wasted tranny (didin't shift 2-3 right ever, failed outright later on) with a race weight of 3710 and you've got my '87 formula.
It's run 13,59@100
It's run 13,59@100
It's run 13,59@100
It's run 13,59@100
Sorry... have timeslips.
also have track video of the car running roughly 14.0@98 on a 98* day with no front end on it and some stock firebird wheels and tires on it (had to let go of the throttle a little before the finish line because all the air catching under the nose with no front end on it was causing the hood to try to come off at that speed...)
I got a box of recipts from him with every little bit of that car documented. It did get some factory replacement heads at 7K miles (originals supposedly had bad valve guides), but no other work doen to it and everything that I've had appart confirms it.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Thats where your going to see your biggest gain. You cannot go wrong with headers.
Car: 1988 IROC-Z
Engine: 427 SBC
I don't mind paying the few hundred bucks for the headers for the performance/sound, I just don't want to put them in. How was the install for you guys?
It was not bad at all. I couple rough spots, but you just have to take your time. Although you might want to ask someone with a V belt setup. My driver side was cake. I had it done in 15 minutes.
Car: 1988 IROC-Z
Engine: 427 SBC
Did you have to take out your plugs? What did you use? A swivel joint and extension or could you reach them with an air ratchet?
I did it with the plugs in. I reached them all with a socket and ratchet. I don't believe I used a swivel. The stock heat shields on the manifolds will most likely give you trouble also. They were a pain.
RedLeader289
05-28-2019 01:47 PM
