M/T ET Street users..come here!!
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I just ordered myself a nice new set of 27x10.5x15 ET Streets for my Z.Is there any break-in for these things?I also emailed M/T..but I also wanted some real world experiences of what works best.
I am also looking for recommendations of how these things should be prepped for each pass when at the track.....this will be in a manual trans car?Long smokey burnouts..short quick dry hops...water..no water?Just wanna know what works best.I know each set will hook different on each different car..just looking to get a starting point to learn how to fully utilize these tires.Air pressure also?Same questions!!
Actually for manual cars mickey thompson recomends little to no burnout at all.. Though it may sound funny, my brother in law was using them on his mid 11 second LSI and having trouble with car bogging even when dumping at 6200 - so I recommended no burnout to try and get some tire spin, still dead hooked on no burnout.
I have used them on my car in years past, go with small burnouts to get some heat in them anymore and you are just wasting the tire. They don't seem to like less than 11 lbs for me.
Don't spin on the street and they will get pretty good amount of miles, don't drive in rain after 1/2 tread. - before that be very careful in rain.
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I do a 4-5 second burnout staying in 1st gear at around 5500 rpm (with 4.10 gears) then let it roll out and grab traction. Also run about 12 psi in them now with the looser converter, ran 13 before with the stock type converter. Go through the water like a normal slick. The more passes I get on them in a night the softer and stickier mine seem to get, which makes sense I guess.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Thanks Guys!
M/T recommends I do a good hot burnout the first time out with them to help the tires final "cure" otherwise a quick burnout at the start of the day when I am racing to heat them up,otherwise after that.. just launch..no burnout.Trial and error will tell once I get some seat time with them.
They also mentioned to measure the circumfrence and make sure it is even tire to tire and stretch them if necessary to make them even...gotta wait to get them mounted up first though.They said to do this before even mounting them on the car as once they are driven on and heated up I won't be able to do it anymore.Interesting.
I'm just hoping to see at least a 1.7ish 60ft next time out and some lower ET's.I ran on some old ET drags that were 26x8.5x15.I know (hope) this car has a 12 something in it somehwere..lol.
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
Originally posted by onebad82z
Thanks Guys!
Thanks Guys!
Dude, you hvae to do a burnout! no matter what anyone tells yoiu. the lenght of the burnout is what you will be trying to determin once at the track..... on et streets I started my burnout then shifted to 2nd, when I got smoke I stayed in it for about 3-4sec then rolled out. They hooked everytime......
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
i went all last year with out doing burnouts. just pull around the water box and a quick dry hop is all i did. i had consistance 1.7 60 foots ran 7.9x in the `1/8th at 5700 foot eleavation(6900foot corrected). oh and i did win the pro class doing this. the car runs 11.7 on motor in the 1/4, and pulls 1.6 at firebird raceway. so it is possible for it to work with no burnouts
i am trying burnouts this year as i am going to spray a 150 shot out of the hole
Mickey Thompson does not know what they are talking about. lol
Originally posted by 87_TA
Your Right,
Your Right,
So I must know more than you think...................
Well that is not for an nmra application -it says stockers.
Like as in guys not running a 12"-14" rim with a 10" tread tire
to stiffen sidewall. and guys that have suspension setups that plant about 2000 lbs of force on launch per tire.
We are talking about cars that need a little bit of spin on the launch - not cars with $2000 adjustable clutch setups.
Congrats! you ran 9's on an ET street!
And..... you thought that was a record?
perhaps maybe you should get a job with M/T so you can teach them everything you know about tires
I apologize for coming across as a smart a$$, it says little to no burnout - If I could get away without doing a burnout and my 60ft reflected the same... Imagine how long your slicks would last! I would sure give it a shot....
Like the application I mentioned above.. Dead hooked both ways dumping @ 6200 - why waste the tire and make have more friction if its working?
82z has a 4sp, 3.73's and a good motor behind it. I am giving him some friendly advice. I can see a stock car hooking but not a stout 355 with a 4sp.........
as for setting a record by runnings 9's???? not a chance it was done long before I was touching 14's However it was a record that night at the track, as I received the fastest street car award..... for the friday night test and tune.........
not sure how much you race, but I am at a couple diff tracks a month. I talk to the races and the dealers enough to get info. As for the job at m/t do they have any openings ??? let me know I could use the extra cash.....
This year I plan to go to Englishtown for some good sealevel air.
I would guess that your fastest street car is an auto? M/T recomends burnout for autos - anyway I think they still know their tires better than you - sorry if you feel different.
At this point who cares - I would be sure if he tries it and blows the tires off, he should do a little heater.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
All points have been proven.I thank everyone for their recommendations.This is getting old..let's end this nicely.Thanks Gentlemen!
take a look at the cars in the psca series http://www.pscaracing.com
all classes use et streets and are running low 8's. the new mt drag radials are used in the wild street class are hauling *** with this tire.
Doobie52
09-11-2015 06:19 PM
