m/t et streets air pressure
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
hey all any ideas on what air pressure i should be running on the et streets i know it takes some playing around with but is there a base line to start?
last time went to the track (first time ever running slicks) i had them at 15 lbs my 60' was 1.9 they are mounted on 16" iroc rims should i play with them?
also what is the lowest and highest i can go on them?
thanks
thanks
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Assuming that your car is stock weight and has 26" or 28" tires, MT reccomends 16psi+.
Don't go lower than you need to. From a starting pressure, work in 1/2psi increments until you don't see in improvements.
mdtoren
08-16-2015 05:45 PM
