PUZZLED--Removed air cleaners and go slower?
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Can somebody splain why, cause I 'm not quite sure I understand. The last time I went to the1/8" mile strip, I removed the air cleaners and the car ran about 2 tenths slower than with them in?
See car mods below
See car mods below
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
My best guess would be because your letting dirt in with you A/F mixture and it makes for worse combustion. Kinda like a K&N filter helps becuase it keeps more dirt out than a regular filter. Just a guess though.
Car: 1989 IROC Z-28
Hey Dude
My car has the stock (restricted I know!) dual air filter plastic intake system + K+N filters--modified MAF (Bosch).
One other person had a possible explanation, that with the amount of airflow with the filters in place --at WFO--the amount of gas being dumped at max matches the amount of air coming in.
With the filters removed there is an increase in airflow volume and even thought the Maf sensed that, it was pumping at max, which he said means that possibly a slight increase in fuel pressure at the AFPR, or in the chip programming, would be able to take advantage of the increased air flow and keep the correct air/fuel ratio.
Now, if that is so, I need to figure out if this IS what is happening.
I guess the first and easiest thing to do is check the fuel pressure and try increasing it and see if it runs any better?
Anybody have any other suggestions?
Thanks,
Craig
Thanks,
Craig
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Becuase air flowing in a striaght line is faster than turbulent air. If you take off the air cleaner you the air entering the intake is very turbulent so not as much can enter. As well as cleaning the air,. the filter helps straighten the flow out.
Think of 100 people running at one door, how long it would take them to get through. Now line those 100 people up in single order, they get through much faster and more efficiently.
Car: 89 Camaro RS
Car: 1989 IROC Z-28
Yes, it is a good analogy, and I completely understand the theories/concepts, ETC. I have years of roundy round racing experiance including crew chief on a top local late model and a season points winning sprint car.
I am running a tpi not carb. For that matter years ago whenever I took my carb car to the track and removed the air cleaner, it always ran faster, with or without the velocity stack.
In this case with the TPI OEM plastic air intake system that has a couple feet of "runner" (for lack of a better term) before it gets to the MAF, I'm not sure that turbalance is the culprit, but then again if I knew what was going on here, I wouldn't be asking these questions!
Thanks for the ideas--open to any and all ideas and theories!
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
adambros, that explanation is worth a million words..I can't see anybody NOT understanding that concept after reading that.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I agree, think it's just s imple case of the hot engine bay air getting tumbled around with the air seeping in around the hood, wheel wells, under car disturbing the air flow.
I've run my car with the $3 air cleaner and it puts up the same numbers as it does with the breather off, but I also have the carb sealed to the hood and sucking through the cowl only for fresh air.
Car: 1989 IROC Z-28
Bests:
60' 1.480
1/8mi. 6.977 @ 98.52mph
1/4mi. 10.985 @ 122.10mph
All through junk paper air cleaner and mufflers
Pretty impressive #'s DUDE!!!
60' 1.480
I could easily run high 10's consistently in the summer with a cam swap since the one I have is so mild, but I dont wanna lose the daily driver, drivability I have now.
Nothings better than spotting a BBC powered gutted race car with open headers Street driving I run 92 octane as well as many non points events I drivve the car to the track for, but when I goto the track racing for points I opt for 110, cuz it smells good
Car: 89 RS
Transmission: TH350
Re: PUZZLED--Removed air cleaners and go slower?
Car: 1989 IROC Z-28
Re: Re: PUZZLED--Removed air cleaners and go slower?
Originally posted by StngKlr
How close were the runs together? Any cool down time? Other than that, I'd say the other explanation sounds good. Its wierd, everytime I take the filters out, the car runs about .1 quicker. Hmm....
Hotrodboba400
12-10-2019 07:07 PM
