13.6's with stock converter... will a 2100 stall help me???
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I always run street tires (255/50's kumho ecsta 712). I usually launch at 1100 rpm (before the tire's start spinning) and ease it outta the hole. Im consistantly in the 1.9sec 60' range with 4.10 gears and posi. If i up the stall, will i burn out more at the line or leave harder? I don't plan on using slicks. i want to run 13.40's on motor alone. Im running 13.60's consistantly now...
i have never driven a car with a stall, is it like slipping a clutch for the first few rpm's and lettting it out at the flash point??
Car: 1991 Z28
Engine: 5.7 TPI L98
I only have one set of wheels and i like the "sleeper" effect of having street radials on factory rims. I would be willing to try some drag radials, but im really happy with the 255/50 kumho 712's.
The price is right too... $93 each
My rear end has been blown a few times. It may have been the idiots installing the gears or the car hooking hard. I have sbf's drag shocks and struts, lakewood lift bars with the lower control arms and the front sway bar gone. With a stall and slicks is my 10 bolt gonna blow again????
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
1 Post
Car: 1989 Iroc Z L98
Car: 85 Trans Am
Engine: 413ci SBC
Transmission: TH-400
Hope this helps with your worrys
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
-Jason
Car: 1991 Z28
Engine: 5.7 TPI L98
Wow, i guess my rear is stronger than i thought. Im sure the reason i broke it so many times was poor installation. I have beefed it up a bit with stronger axles and a TA cover. I think i will go with the mild stall now.. thanks for the input.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
A little higher stall speed will help your cause for quicker ET, but if your dead set on not installing slicks or some sort your pizzing up a tree. The slicks alone would probably net what your after, once you install the 4.10's, your done as far as street rdial tires are concerned. The stock 12" convertor you have now is already saoking up alot of the hit, once you go to a higher stall speed which will more than likely be at least a 10" or 9.5" convertor, you will be the John Force of the runs you try
For the record, when I was only running 13.5 I blew 1 rear end, when I was running 13.00's I blew out another 3. All were with slicks and all shaved the teeth off the ring gear, never in 4 diffs did the pinion gear ever look worse for wear, it was always my ring gear.
When you get really serious about getting the best pass you can, buy or borrow a set of stickies from somebody and be done with it, until then your wasting your time having to pedal it outta the box.
