What will my 406 run?
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
What kind of times do you fellas think I will run in the spring. I have a 406 small block with crappy 882 heads, 280adv 230@.050" .480" lift cam, zz4 aluminum intake, barry grant speed demon 750 vs carb, hedman 1 5/8" long tubes, dual 2.5" exhaust, 700r4 with a 3200 stall, 3.08 gears, and street tires
Adam
Adam
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
i would say mid 13's or so. just a guess, but your heads are really hurting you. better gears would be nice too, and a cam with bit more lift, like a hydro roller or solid roller. a cam like that with better intake manifold and heads to flow enough will really open up that car LOL just my thoughts.
Car: 1985 Z28
Engine: 383
I am going to get new heads and a new intake manifold next summer when I get the money. I will also be getting a set of 3.73 gears then. Until then, I will just have to work with what ive got.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Mid 13's sounds about right. At one time there was a 406 in my bird . It had a similar cam but dart 2 sportsman heads and ran 13.4 @105 with no traction. It had 3.73s though. I only ran it that one time because it hydrolocked on the next run. It would have gone low 13's high 12's if I had more time with it. My buddy had a 4 speed 1970 nova with a 408 and Iron eagles with a small solid cam that ran low 12's with 3.08s
Fast355
12-02-2016 06:33 PM
eightsixseven
08-14-2015 03:09 PM
