2005 NHRA Rulebook
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
2005 NHRA Rulebook
Heard a rumor that the 2005 NHRA rulebook may include an ET Break change from 11.99 to 11.50 to be consistant with the new Pure Stock class. Anyone else here anything?
Car: '82 Z28
That's how I read it... Find out soon enough after the first of the year when I go to the track again Still going to put a roll bar in since a bigger engine is going in the car.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
More than a few track owners are not thrilled with the rule change. I would not be suprised if some tracks will still go by the 04 rule. E-town in NJ is 1 track rumored to stay w/11.99 rule. I hope the 11.49 rule IS widely accepted. No Roll bar for me.
Car: 86 Trans Am
Engine: 406
I also wonder how many guys will be affected by the crank centerline rule.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
-- Joe
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Primarily for trucks.
They're limiting how high off the ground the crank centerline can be. The faster you go, the closer it has to be to the ground.
Nothing you should have to worry about.
-- Joe
