Hope to improve with new gears/posi!
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Last time at the track in august I had just put the commander 950 on my new engine, tuned just the idle and ran her. She went 13.3 @ 106.2MPH with a 2.1 60ft time.
Current gears are 3.23 peg leg.
Just got all this stuff to put in this weekend.
Richmond 3.73, Eaton Posi, rebuild kit w/ solid crush sleeve.
After I get her in I hope to erase that 13 in from and make it somekind of a 12. What do you guys think?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
It's efinately a step in the right direction. Are you running any sort of stickies out back? that will help too.
Not yet, could just afford the posi/gears/diff cover before the track closes this year. Spent the spring rebuilding the engine, then the gm computer died and I had to use my rear money for a commander 950!
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Make sure you get that WOT tune in before you make too many passes. You would hate to damage your new motor. Sounds like you will have a wicked combo when complete.
Have a feelin I've been running a little rich, but not lean. There is no knock, and a bit of black if you follow me. Friend has a WB. Gonna go use that after the rear install.
Pulled the rear tonight. The old posi (yeah it was an auburn) you can move the whole clutch pack inside 1/4" and the axle retaining pin up and down a good 1/8th! Ouch. There was no posi goin on inside there, just sloppy.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Originally posted by Dewey316
Does this mean we are not going to tune by me following you and telling you how much smoke there is "Nope, you still look rich"
Originally posted by rjmcgee
Your gonna be going fast,
just not fast enough.
Hey, I've never seen red or white OR BLUE car taillights.... hey what do they look like?
sjorgens
10-01-2015 07:54 PM
3.8TransAM
10-01-2015 07:47 PM
