305 TPI Times?
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
305 TPI Times?
What do you guys think a 305 TPI with full exhaust, Hot cam, rockers, Valve springs,TB , full racing tranny (Auto ) and a LSD would run? 13's?
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
No, not 13s.
Depends on lots of things though; gears, tires, stall speed, etc. would all factor in moving you up or down in the 14s range. Just my opinion.
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I don't see why it wouldn't, unless you have some tuning/combo problems. Just get traction and your good.
My cam is nowhere near the size of a hotcam, and I still have stock rockers among a bunch of other stock items. It's really hard to tell, actually.
I've seen "modded" 305s turn some ****ty times but I've also seen some extremely mild ones turn high 13's
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Re: 305 TPI Times?
hot cam is too big for a 305, i wouldnt use it. a better cam, head work and the rest of ur stuf and 13s should be obtainable.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
hot cam puts your power way above TPI range especially on 305. A smaller cam would serve you better. hot cam probly would need serious tunning to help it run good. My guess is low 14's if you use all that torque off the line and cut a good 60' time.
Sanjay
08-12-2015 03:41 PM
