Goin to the track tomorrow...13's here I come
#51
Engine: L98, Hemi 6.2
Yea Tune Port youhave really good times, Its just your Trap Speed is a lil low. You should be in the 100-102 mph range, right?
#52
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Ahem....
Originally posted by TunedPort 335
PS guys the reason my traps are so low is because the tranny still wont shift at WOT, i have to let out of it just a bit... I think I need to change my governer gears or something. Otherwise I'm sure my traps would be in the 99-100mph area
#53
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
#54
five7kid, you are correct
When I lost my 3-4 gears my 3-4 clutch pack was fryed. It wouldnot shift into 3rd at WOT and then wouldnt shift into 3rd at all. It sucked but I got it fixed a week later and is great!!.
Tuned port, you need a tranny rebuilt. You will deffinately see some low low thirteens.
#55
1 Post
It will shift at WOT when i raise my rev limiter, but I am not doing that. As you know TPI doesn't make much power up top.
