G- tech #s
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
G- tech #s
I bought a G-tech today and I did a run with it and it said that I ran 15.21 @ 98.6.Doesn't sound very good.I know they are fairly accurate but I can't wait to get to a track.
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
umm sorry to say this but they are normally a tenth or 2 faster than what you are really getting
jon
jon
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
jon
jon
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The g-tech mph will always be higher because it gives the mph exactly at the 1/4 mile mark. Dragstrip MPH is a calculated number from the time you break a timing beams 66 feet in front of the finish line to the finish line. Since you're still accellerating that last 66 feet, the calculation isn't 100% accurate of your mph exactly at the 1/4 mile mark.
Car: 87 IROC L98
Depends on your point of view. It gives the exact mph at the finish line however not everyone has access to a g-tech so for the majority of us, time slip mph means more. I can really screw up my mph when I go hard on the brakes at the finish line to keep from breaking out. ET drops slightly but mph takes a bigger hit.
ET is pretty close to the same with both however garbage in/garbage out. If you input the wrong numbers into the g-tech, you'll get an incorrect result.
Pac J
05-17-2020 10:44 AM
