Safety loop???
Car: 88 camaro RS
Engine: that thing under the hood?
Transmission: a what????
Safety loop???
what is the NHRA req. on the safety loop. i mean where does it have to be mounted (how far from the tranny?) i tried to look on the website and couldn't find it.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
In the 2004 NHRA rulebook there is a illustration that indicates it should be no more than 6 inches back from the front u-joint.
Car: 88 camaro RS
thank you so much i thought 6inches sounded right just didn't know if its was more or less. but thank you so much.
Car: 87 Firebird Formula
Engine: 305 LG4
2.4 DRIVELINE
On any car in which the driver sits over or in back of the rearend center section, a suitable protective shield of .120-inch (3 mm) minimum thickness steel plate must be installed for those units with universal joints securely mounted to the rearend center section and the bellhousing adapter. Where possible, couplers are recommended in place of U-joints. For straight couplers, the minimum requirement is .063-inch (1.6 mm) aluminum which must contain an inspection cover for removal and inspection of the coupler, securely mounted to the rearend center section and the bellhousing adapter, or as noted in Class Requirements. In place of a crossmember, in the vicinity of the front universal joint, all cars in competition using open driveshafts, must have a retainer loop 360-degrees of enclosure, 1/4-inch (6.35 mm) minimum thickness and 2-inches (5.1 cm) wide, or 7/8-inch (22.2 mm) x .065-inch (1.65 mm) welded steel tubing, securely mounted and located within 6-inches (15.2 cm) of the front universal joint for support of the driveshaft in event of U-joint failure. Recommended the loop be round rather than oblong to minimize loading on loop. Open drivelines passing any part of the driver's body must be completely enclosed in 1/8-inch (3.2 mm) minimum thickness steel plate, securely mounted to the frame or frame structure.
luvofjah
09-26-2015 08:28 PM
WhteRbt
09-21-2015 09:48 AM
