1/8 mile time estimate ??
Car: 87 IROC - Z
Engine: 406 smblk
Transmission: 4 speed manual
I'd like an estimate on times here is my mods 87 iroc 406ci 230 duration 480'' lift stock 882's 040'' over heddman lts 2.5 bullets 800cfm holley rpm intake 100 shot of juice 4speed trans 327 gear
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
OK I'll go out on a limb and guess 13.2 with good traction running only on the motor. 12's should be easy with the N2O.You will probobly need slicks to get it to hook tho.
Car: Camaro drag car, 98' c1500 vortec 350 for daily driver
Engine: whole bunch of tree fitties
Transmission: same as above
I we have here where I live are 1/8 mile tracks. If you have slicks and get it too hook, no problem running a high seven. Most of the stock l98 cars with good drivers around here are running high 8s with slicks and low 9 completely stock. Hell take a look at my car. That was before I turned it into a drag car with a 406, ladder bars, no interior, cage, and slick. Now with an N/A motor Im running a 7.3 with a 10.5 inch slick. Have fun and keep it on the track.
Hip Hop
Hip Hop
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: 1/8 mile time estimate ??
Originally posted by 406iroc
... stock 882's ...
... stock 882's ...
Mid-high 8's.
1 Post
Car: 1989 Iroc Z L98
Re: Re: 1/8 mile time estimate ??
Originally posted by five7kid
That's going to hurt you right there. Put a bottleneck like that right in the middle of the system, nothing else you put on either side is going to make much difference.
Mid-high 8's.
Mid-high 8's.
Car: 88 camaro
Engine: 13 to 1 406
Transmission: th 350
if you can drive it I think it will run mid to low 8's but if you dont power shift probably low 9s. I used to run a 406 with 10 to 1 compression vortech heads 230 @ 50 cam and a 5 speed before I broke it with 3:73 gears car ran 7.80's using 1-2-3 gears but the vortech heads are a whole lot better than the 882 s
