Need to know some specs
Car: 87 z28
Engine: 5.0
Transmission: t5
Hello i am curenty fabricating a 3rd scale tube chassis and useing a third gen as a base, This chassis would be for road racing and i don't curently have my third gen or any other for a referance so if any one can give me these demensions it would be a great help
1. What would be the best ride height for a road race because i need to set disired ride height
2. What diameter tire is the largest you can use and would fit stock with out modification
3. i would also need tire bluge to bluge width of one tire
4. wheel base of car
5. Front cross member hight (at set ride hight)
6. front cross member width
7. leading edge of front cross member to front axle center line
8.frame center section outside width front
9.frame center section outside width rear
10. rear cross member hight (at set ride hight)
11. rear crossmember width
any and all help will be greatly apriciated
TX-SleeperC5
09-24-2015 03:13 PM
