new times with new setup
Car: 89 Iroc
Engine: 350 vortec TPI
Transmission: 95 T56
new best
1st run 13.52 @107.15
2.43 60'
1/8 8.91@ 84.86mph
2nd run 13.42 @104.61
2.31 60'
1/8 8.78 @ 84.11
the second run i shifted higher than the first at around 6000 rpm the first was at like 5700.
I thinks some of my problem is in my 3:27 gears with T56. I was running 245/50/16 Kumho. what do you guys think?
2.43 60'
1/8 8.91@ 84.86mph
2.31 60'
1/8 8.78 @ 84.11
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Poor 60' times. You lost HP on the second run probably from the higher shifts.
When I had a 383 stroker runing high 11's I was using 3.27 gear, TH350 tranny, 3800 stall converter and 27.3" tall tires.
Your tires are only 25.6" tall so going to a deeper gear could easily overpower them.
Get some slicks to help control that wheel spin and your ET should drop.
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Car: 87 IROC L98
Originally posted by 84firebird383
yuck that had to suck on the street.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Trust me it's your gears. I'am in the same boat with the 3.27's, they suck with are first gear, good thing I have a set of 4.10's sitting beside me waiting to go in
Hey what clutch setup are you using and how does it perform.
Car: 89 Iroc
Im running the mcleon clutch with zz4 pressure plate. It works great has a nice firm pedal and grabs hard. I know what your saying about the 3:27 with the t56 first gear sux, driving in parking lots or stop and go traffic is horrible. I think some 3:73 would make my car rip. I need to run 12s soon.
Car: 89 GTA
SPEC stage 2 kevlar crap, I'am not happy with it at all. If you try to launch the car at 3-4 k and let the clutch slip tell you get moving the clutch will be done for the rest of the day. Even my cheapo clutch for my t-5 when I had that in there performed better then this piece of ****, and I cost 3X less.
Looking for a new setup, maybe a SPEC stage 3 but I'am not to sure anymore.
Terrell351
06-13-2021 01:13 PM
evilstuie
01-09-2020 08:29 PM
Street Lethal
08-13-2015 08:28 PM
