who here has the lightest street driven thirdgen?
1 Post
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Ok I'll go first. I drive my firebird to work about 2 times a week and cruise on weekends, go to track when I can. It weighs 3,050 pounds without driver, and a half tank of gas. Next time i weigh it, it should weigh 2,9XX because I've removed some stuff since the last time I weighed it.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
mine was 3615 with my tools, me, subwoofer and 3/4- full tank of gas...
minus me and tools, its closer to 3375...
so i'll put me down for 3375 in the lightest vert category. :lala:
(if someone doesnt beat me, i'll be disappointed.)
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I need to get my car weighed ...I'm almost clueless on what it weighs. I'm guessing anywhere from 3200-3500lbs
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
weighed mine today full tank of gas and me (235lb) in it 3700 pounds. now it seem more impressive that i ran 129.77 in the 1/4 2 weeks ago on the break in run
mike
mike
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: who here has the lightest street driven thirdgen?
I need to reweigh my car before the start of the season to see how much my winter changes did. My race weight last fall was just under 3200 pounds. I'd love to get down to 2800 pounds but that's a lot of weight I need to remove and there's not much left.
1 Post
Car: Junk
The scales said 3210 with me in it. I'm a slim 155 pounds. I'm hoping to get it down to 2,9XX or so with me out of the car next time I weigh it. I think people should post what their CAR weighs not what your FAT *** weighs heheheh. Too hard to try and subtract whatever your weight is. Just list your car weight.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
My stock non T top '88 GTA weighed 3380. I removed the A/C, but installed a bigger, heavier radiator and put on subframe connectors. We'll have to weight (ha ha) and see what it is when all the AC stuff is out. It is otherwise full of every option available.
i weigh 190lbs, but that's not really very fat considering I'm 6'4". If I get any skinnier, I wont' have a butt so sit on.
Troy
So Cal
Troy
So Cal
Car: 91 Camaro Vert
Re: Re: who here has the lightest street driven thirdgen?
Originally posted by Stephen 87 IROC
And how often does the car drive around without a driver? Total weight or what I'd rather call Race Weight, is how much the car weighs going down the track. A 3050 pound car sounds light but when you add a 150 pound driver, the engine is trying to now move 3200 pounds.
the reason you tell the driver weight, is that more then one person could drive the car...
if i let a featherweight like ChrisFormula355 drive my car, hes going to be a lil faster then me... but only because of the weight diff.
thats why i list car weight, my weight and race weight.
1 Post
Car: Junk
Re: Re: Re: who here has the lightest street driven thirdgen?
Car: 91 Camaro Vert
Re: Re: Re: Re: who here has the lightest street driven thirdgen?
I've actually had friends have me drive their car down the track because they were a good 100-150 pounds heavier than me, and their car did in fact go a few tenths quicker
Car: 1984 Camaro z28
My car weighed in at 3505 with me and an almost full tank. Id like to get some weight out of it but it handles great now and snice i drive the car everyday i dont know how to drop weight without spending alot of money or giving up seats and things like that
1 Post
Car: Junk
I should officially be about 2,990 pounds this Friday when I weigh the car. I removed approximately 60 pounds worth of crap today. Removed the in dash speakers, the rest of the wiring harness that isnt' being used (former TBI car), some more stereo junk that was hiding under the passenger side dash, the windshield wiper motors and arms and stuff, and some other miscellaneous stuff! The reason for all this?? I want to hit mid 11s on motor before I spray it to 10s!! The easiest I see doing this is in a 2,900 pound car. What really sucks is next time I go to the track (april 30th) they are going to boot me for sure and I really don't ever plan on installing a roll cage Whats really cool is I still drive this car to work and school a few times a week. How many people with 10 second cars can say that?? well ok its not officially 10s yet but it should be pretty easy to squeeze into the 10's with it being a 100 pounds lighter than it was running mid/high 7 second 1/8 mile times all motor. woot.
oh and **** I just remembered one other thing that is going to save me at least 40 pounds....................the HUGE heavy rubber aerowing on the back of my car!! Thats being replaced with either a fiberglass aero wing or a junkyard base model firebird wing ASAP. Its dead weight
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Buncha light wieghts
Wow!, All of those wieghts are light compared to mine....it`s a whopping 4,060 #`s with me in it and a full tank
RF) 1200 #`s
LF) 1150 #`s
RR) 850#`s
RL) 860#`s
This wieght was taken two years ago and and I have slimed it down a little, aluminum water pump, lighter alternator and brackets, Removed the a/c box for a delete box, Have a tube k-member, a-arms, and coil over kit to be installed and still need to move that battery to the back. Aluminum heads would probably be the biggest wieght savings but at 2,000 + it`s not gonna be anytime soon, the M-6 will come before those. 11.20`s with a 1.6 sixty time is decent for the wieght even with a rat.
RF) 1200 #`s
LF) 1150 #`s
RR) 850#`s
RL) 860#`s
Car: Sexy
Engine: Stock
Transmission: Slipping
3550 with me in it, *with* the A/C removed, aluminum radiator and water pump, very little stereo, 1/2 tank gas... I feel fat.
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Just yesterday I drove my car to work(in the rain )and went to the track right after work, pulled up to the line with no changes other than rear tire pressure and went 11.22@120mph Thats on pumpgas which is equivelent to you running n/a, I'll be running racegas this Sat and looking for at least a 10.50
My car is usually around 3530 raceweight(depending on fuel and what tools are in the car), I'm about 250-260 so figure the car alone is around 3270-3280. The reason I think my car is so heavy even with alot of weight reduction is because of all the heavy parts I put in it like the SSM subframes, mild steel 8 point bar, TH400 trans, chrome moly driveshaft, and 12 Bolt rear.
BTW, raceweight IMHO is more important than unlaiden weight. Like Stephen 87 IROC said, how often does a car drive around without a driver.
Steve
1 Post
Car: Junk
Originally posted by TTA850
I can I drive my car several times a week to work, to car shows and cruises, and of course to and from the track
I LOVE driving to work (I work at an auto parts store, dont' laugh, I'm a starving mechanical engineering student!!) and listening to customers brag about having a tubbed out race car they trailer to the track and run 12's in, then I point to my firebird and tell them the 1/8 mile times I pulled off and they just give me a stunned look like "wtf did you just drive your race car to work??!?". hahahahha shweet
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
My car is 3330 lbs, without me in it and 1/2 tank of fuel (about 8 gallons, or 50 lbs). No A/C or P/S. Pretty light though considering it's a roots blown big block car (all steel, full interior) with a big honkin' Dana 60 rear end! It's also back-halved with a full roll cage. Weight distribution is F/R: 57.9/42.1 percent, with me in the car (160 lbs), at race weight (about 3500 lbs). Good for mid 9's @ 145 MPH so far, running on pump gas.
Car: 1976 Camaro LT
Transmission: TH350
my old 91 rs weighed in at 3280 with me, 200lbs, and a half tank of gas. the car still had a bunch of stuff in it too, power windows/locks/hatch release. only thing anyoen coudl ever see was missing was the back seats.....hehe. my car also had road racing brakes at teh time. not bad for a street legal t-top car i think.
my new toy is a 83 Z28 hard top. plan togo super weight **** on it and i will actually document where all the weight comes out of the car. the "little things" actually add up to a lot mroe weight than you woudl think, my odl car was pretty good proof of that.
later
tim
later
tim
Axle/Gears: 9bolt
i was thinking (Ruh-Rhoh!!) that some good places to drop significant weight would be:
Replace rr glass with Percys' "speed glass"
swap rear spoiler for fiberglass or earlier version
Replace the hood with fiberglass
Tubular crossmember
Aluminum heads
Air Cond Delete
Lightweight wheels
Have any of you guys used these methods?
What other methods would you suggest for a STREET car?
Troy
So Cal
Tubular crossmember
Aluminum heads
Air Cond Delete
Lightweight wheels
Troy
So Cal
Car: 1976 Camaro LT
Transmission: TH350
try to think small.
look at the dumb things on the car, how many bolts does it take to hold down a fender, correct answer is 2(1 at each end) gm's answer was 5. when shimming a fender to align it what is teh best material to use, correct answer small pieces of aluminum, gm's answer was about 2lbs of steel shims per side.
these are the kind of little things that i see so amny people miss out on so often because they think"that pound or two isn't enough to help", well, that individual pound or two may not be, but all the things that get skipped because of tht thinking does add up.
i was told a long time ago by an older street racer, " it isn't 100lbs, it is 1600oz's." everything counts, no matter how small.
later
tim
later
tim
Car: '82 Trans Am
Transmission: TH475
Originally posted by xpndbl3
when are your pics going up on a website to check out this ride?
1 Post
Car: Junk
I spent 4 hours at the car wash removing stuff today:
dash pad (replaced it with dash cover)
hatch struts
all vents and metal supports for vents
heater core
wiper motor, left wipers in place (for legality)
security compartment in rear hatch
I figure this about 50 pounds total worth of stuff. The dash pad was really heavy, and there was a lot of other miscellaneous crap.
hatch struts
heater core
Car: Turbo Buick
Engine: 3.8 V6
listing your cars weight with your weight included has to be about the most annoying thing i ever come across on the internet. The only reason I would want to know your race weight is if I had a trap speed for that same run and I wanted to calculate your horsepower. Other than that there is no friggin point other than you are just giving me a number with one huge variable.
When people ask about car weights on here they dont want to calculate your hp they wanna know if they can make their car any lighter; for the love of *** why not just list your car weight without you included
that seriously annoys the **** out of me
btw mine was 3250 with a 700r4 and a bunch of other crap.. ill bet im at like 3000 now. The nose sits rediculously high off the ground. I think the big thing there was removing thecrash beam and relocating the battery thats around 70 lbs off the front alone not to mention no smog pump or AC
dont forget removing the crash beams if you want to drop a whole lot of weight at once chris
1 Post
Car: Junk
2960 with about 3 gallons of gas in it. And it still has carpet and "appears" to be a street car on the inside, hahahahha. Remember i have aluminum heads, water pump, radiator, and everything else, but I also have a really heavy 3inch DUAL x pipe exhaust with two big heavy stainless steel magnaflow mufflers.
Hey Pablo.....long time no talk....how do I remove the crash beams and where are they?? Are you talking about the beams in the doors??? If so whats the procedure, I'll start gutting them my next day off
1 Post
Car: Junk
he's talking about that HUGE crash beam in the front of the car under the nose. i pulled mine as well. every bit helps.
You mean the bumper??
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Is it true that every 100lbs = .1 in the 1/4 mile???
my rides weighing in at 3380 without jockey + 220 pounds of pure pain personal trainer takin weight gainer in the driver seat. haha,, Its 3600.... race weight.
does anyone remove the sway bar at the track? How much weight reduction? It should make the front raise easier for better traction right??
am i crazy if i remove my rear drums and only rely on my front brakes? This is for the track only, Byron IL. dragway has a slight uphill shut down lane with alot of room too slow down... This will also reduce rotating mass weight, which will free up a few more HP....
has anyone done this?
Car: 1976 Camaro LT
Transmission: TH350
good to see you are still nice and calm pablo. you always add such flavor to the threads with your retarded ranting.
here's an idea, if you don't like how people write things, stop reading....duh
later
tim
later
tim
Car: Turbo Buick
Engine: 3.8 V6
hey chris the crash beam is basically the bumper, underneath the nose, just unbolt the sucker and drop it down from underneath the nose. You dont even have to take the nose off to remove it, there will be a ton of plastic crap infront of it too. that weighs probably as much as the beam itself. there is also one in the rear but i left that one alone. You could probably drop almost 100 lbs removing both of them im guessing.
and NJspeeder i love you too man!
