slick size
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
slick size
Will 29x10x15 slicks fit on my 1990 GTA ? I just got a used pair for free, my friend bought some new ones. I put them up next to my tires on the car and they are barely an inch taller than my 255x16 Firestones and not a lot wider. Anyone run this size with stock suspension ?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not without some sheetmetal work. That's the size I use. I have my bump stops cut off. The passenger side spare tire indent has been hammered in. The front lower inside corners on both sides of the inner fenders has been cut off below the floor line. That's all when using a 10" rim with 5.5" backspace.
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Originally posted by mod313
30 x 9 x 15 radial slicks fit fine with correct offset rims. Those should fit as well.
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
I'm running a set of Weld Pro Stars 15 x 10 with 5.5 backspacing. Plenty of clearance all around both tire and wheel.
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks for the pics, those are some awesome launches! My slicks are also Hoosiers. What psi do you run?
Car: Camaro
When the air and track are good I go as high as 24 psi. Radial slicks use higher pressures generally than bias. Once you get used to running them, radials are great but you do need to swap them side to side very regularly to keep the sidewalls alive.
Car: 87 IROC L98
I know of a lot of "stockers" who now only use radial slicks. I wish they made them in more sizes other than 30x9.
Pac J
05-17-2020 10:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
