fuel cells.....
fuel cells.....
does anyone know the rules that would apply to us 3rd gen guys as far as mounting a fuel cell in the car?
need to order a rule book
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Fuel cell and lines must be isolated from the drivers compartment. All the specs are in the rulebook. There are still some pics on my web site of how I mounted my cell in the rear and fabricated a rear firewall. The fuel cell is now moved to the front of the car (battery relocated and sealed off differently)
Car: 87 IROC L98
Depends on exactly what you want to do with the car. 4 gallons of fuel in a cell is a lot less than fuel in a factory tank. 4 gallons in a factory tank isn't very much inside a large tank and you should try to have the same amount of fuel on every run to keep all the variables the same.
A factory tank also weighs 25 pounds empty.
im going to put my cell back where yours is stephen,
but since my car sees alot of street use im going to use a 15-16 gallon cell (appropriately sized to fit back there)
probably fab up a hinged/latched cover of required thickness aluminum to go over the top.
you can get them with built in GM sending units for the gas gauge too...which is b/a
the one i was looking at was plastic/polyethylene or whatever, foam baffled, and sumped with 2 -8 outlets, a -6 return on top, and a -6 vent port....it was only like 180 bucks from summit....and rci makes a similar one in aluminum for 220 bucks, both with the fuel sender
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
I have a 15 gallon fuel cell in my car, custom made by Triangle Engineering. Even though my car has been back-halved, you can set your car up similarly, at least as far as the firestop is installed. The carpeted "shelf" over the fuel cell (picture below) has a piano hinge at the front, so it can be pivoted forward to gain full access to the "trunk" area, and to remove/install the fuel cell as necessary. It also has an aftermarket fuel sending unit that is compatible with the factory fuel gauge, and a direct read dial on top of it to watch as you fill the tank.
Car: 87 IROC L98
By the rules there should be a rear firewall. If you don't have one and tech refuses to let you race then you don't race. You could mount a battery behind the drivers seat and mount a NOS bottle beside the drivers seat without a purge tube if you wanted to but neither will pass tech.
Tech inspectors are not highly trained personel. They have a rulebook just like you and at times try to look at over 100 cars in a couple of hours. That means each car gets looked at for only a couple of minutes to try and get everyone through tech as quick as possible. Don't be surprised if they miss something one day then catch it the following week.
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
