what 60ft is attainable with...
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
im curious as to what 60ft i can get with this setup:
Bmr trak pak
alston SFCs
bmr LCAs
lca relocation kit
3.45 gearing
aluminum drive shaft
255 50 16 BFG drag radials
air bag in the right rear
posi of course
350-360hp
5spd tranny, ill have to slip the clutch so i dnt explode the t5
and 3200 weight with driver
Bmr trak pak
alston SFCs
bmr LCAs
lca relocation kit
3.45 gearing
posi of course
350-360hp
yeah the 255 50 16 BFG drag radials are going to be the biggest help. definitely would see the low 1.6s at least i would think.
the biggest problem is 60 foot me also, i still spin now with all my suspension mods, i need some real drag tires this time. at least i dont wheel hop or flex anymore.
Car: '91 Firebird
Engine: 408 SBC
Re: what 60ft is attainable with...
Car: 1999 Z28
ill probably do a few runs where i drop it at like 3500 or somethin and see how it reacts. not to pat myself on the back but i think im a pretty good driver so if the car is capable of a 1.6 or even a 1.5 i should be able to get it there. as for shifting i dont power shift, i do the normal routin let of the gs push in the clutch, shift the gear nail it, but as fast as i can, ive made abou 100 runs in this car and it hasnt broken the tranny so i guess my shifting is acceptable for a t5. i reallly rip on the shifter tho, if i do a burnout on the stret there is about a foot to a foot and a half space between the marks.
i guess im just lookin for what the car should be capable of doin with those suspension mods, lol with an extremely good driver behind the wheel.
Car: '91 Firebird
Engine: 408 SBC
'91 Firebird
Jegs Rear Trailing Arms
Jegs Torque Arm
Jegs Subframe Connectors
BFG Drag Radials (235/60/15)
Best 60ft to date: 1.915
Jegs Torque Arm
1 Post
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Stock everything out back, 3.08s
255/50/16 BFG DR
2.147
What would be the best thing to buy, Lower Control Arms and Relocation brackets?
255/50/16 BFG DR
2.147
Car: 1999 Z28
255/50/16 BFG DR
2.147
255/50/16 BFG DR
2.147
with drag radials u should be able to do 1.8 even on teh stock parts. run 18-20 psi of presure in them and slip the clutch as hard as u can at 3500 when launching this should work better for u.
Car: 83 Z28
Engine: 355 SBC
Transmission: TH400
Axle/Gears: 3.70
83 Camaro
Spohn Torque Arm
Spohn LCA & Panhard Bar
welded SFC
Lakewood 90/10 drag struts
Competition Engineering shocks
Airlift bags
ET Streets (28X11.5X15)
Best 60ft to date: 1.803
ET Drag (26X10X15)
Best 60ft to date: 1.742
Spohn Torque Arm
welded SFC
Airlift bags
ET Drag (26X10X15)
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
darwinprice
17
10-11-2015 11:51 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
TRAXION
87
11-22-2008 10:33 PM
