Dry cell battery rules.
When moving the battery to the rear of a third gen camaro and you plan on running it at the track I know you must have a sealed and vented battery box. If you have a dry cell battery, such as an optima, do you still need the sealed box to pass tech?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes and it's a constant complaint with NHRA rules. All batteries must be isolated from the drivers compartment including Optima batteries.
Car: 87 IROC L98
General regulations 8:1
All batteries must be securely mounted. Rear firewall of .024" steel or .032 aliminum required when battery is relocated in trunk. In lieu of rear firewall, battery may be located in a seal approved box. If a box is used it must be vented outside the body.
Buy a rulebook! You either need to install it in an approved box or fabricate a proper rear firewall to isolate it from the drivers compartment.
3.8TransAM
09-27-2015 08:37 PM
