This this would cause reduced ET/speed?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Think this would cause reduced ET/speed?
Not sure when it happened, found it yesterday while doing something else.
To think, it only took the shop 3 days to put those bushings in.
I think I understand now why the alternator bracket was loose during Super Chevy 2 weeks ago.
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
I doubt it would cause a reduce in your et but would definetly make a clunking noise over bumps did the bolt break off in there or just fall out?
Engine: LS1/LQ4
Fell out.
I guess it wouldn't "reduce" ET, although it might reduce "performance". (Must have been more tired than I thought last night when I wrote that.)
It was pulling to the left slightly, more noticible when braking. New bushings due in today.
Engine: LS1/LQ4
Bushings arrived, new guts installed.
The control arm was moving back and forth as well, changing caster. Hopefully this will solve all that.
We'll know Friday night...
Pac J
05-17-2020 10:44 AM
dimented24x7
09-17-2015 06:58 AM
