what kinda 1/4 et's would you expect?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
assuming car has good traction, good weather etc what kind of time would you expect from this combo? about 300 rwhp 350 rwtrq through a drag built th350 with standard gear ratio's with a 2500 stall and 5 13's in the rear, car is about 3200lbs race weight.
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Need some tall tires to knock down that gear ratio...
But you should hit 12s easily unless no traction and the gear ratio runs out.
how tall of a tire? my only fear would be runnin outa gear before finishin the run
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You're going to need close to a 31" tall tire or else you're shifting around 7500 rpm to use those gears.
Assuming your tire/gear combination is set up for 1/4 mile, your torque converter stall would be too low.
Based on a power to weight ratio, you should be able to do the 1/4 around 12.8.
RedLeader289
05-28-2019 01:47 PM
HoosierinWA
10-07-2015 10:15 AM
