I'm buying a fourth-gen. Any ideas on what it'll run ???
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Dynoed at 386 hp and 360 lb. ft at the wheels.
LT4 heads and intake. Accel DFI.
3.73 gears, T56.
All in a 95' Trans AM.
At a 15 percent loss thru the drivetrain the motor is pushing 455 hp and 425 lb ft at the crank.
What kind of times will a car like this run? The suspension is where it'll need work. It has eibach lowering springs on it and Bilstein shocks. I believe the rest is stock. 17x9 SS wheels with good tread for traction.
What if I got some slicks?
3.73 gears, T56.
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
12.2-12.5, depends on traction. I wouldn't go with slicks as the rear might end up breaking.
You won't be able to really dump the clutch with that setup anyway. Get some drag radials and finesse launch it.
My 96 WS6 Formula ran a best of 12.4@111 with a 1.75 short time on Nitto Drag Radials. Not riding the clutch but having "fast feet" kind of launch. Mine had stock heads but the HOT cam.
Sounds like a nice car. Good luck.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Originally posted by pheonix305
i thought it was a 10 percent power loss through a manual transmission?
I would guess at 3400 lbs that car is gonna be somewhere around high 11's -> low 12's depending on the tires.
1 Post
Car: 1989 Iroc Z L98
Originally posted by ChillPhatCat
Nope... both are wrong... the T56 is claimed at 12% loss by GM...
Car: 91' RS
Engine: Built 355
you sure I can't run slicks???
I think it's about as strong as you can make the 4th gen rear without totally modifying it. The car also has BBK LCA's and a panhard rod. Next it needs LCA relocation brackets because it has Eibach lowering springs on it too.
A guy in GMHTP magazine had a car with almost Identical power#'s and 4.10 gears. He ran a 11.3 on drag radials or slicks, can't remember.
My guess at the very best is 11.7 or 11.8. I think with a "decent" 60 footer it'll run super low 12's all day.
The previous owner got the car to run a 12.37. He is 43 years old and didn't really look like the quick shifter to me, plus he said that traction was a real pain.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You lose a lot more through an automatic transmission. It takes a lot of HP to power the hydraulic pump and rotate the clutch assemblies inside the tranny.
Fast355
12-02-2016 06:33 PM
mustangman65_79
08-11-2015 03:17 PM
