1986 Iroc at the track
Car: 1986 IROCZ
Transmission: 700R4 w/ stage 2 shift kit
I went to the track for the first time this year with my current setup as follows.
Stock 305 TPI engine with Jet Chip
160 Thermostat
B&M stage 2 shiftkit
headmen headers with2 1/2 in pipe w/ flowmaster 3 chamber
MSD superconductor wires 8.5 mm
corvette 02 sensor
everything else is completely stock
first run:
rt - .237
60 - 2.482
330 - 6.706
1/8 - 10.160
mph - 71.42
1000 - 13.126
1/4 - 15.621
mph - 90.90
second run:
rt - .217
60 - 2.185
330 - 6.301
1/8 - 9.766
mph - 71.06
1000 - 12.705
1/4 - 15.262
mph - 90.35
third run:
rt - .234
60 - 2.120
330 - 6.153
1/8 - 9.562
mph - 72.13
1000 - 12.505
1/4 - 14.985
mph - 91.37
forth run:
rt - .204
60 - 2.117
330 - 6.153
1/8 - 9.566
mph - 72.00
1000 - 12.516
1/4 - 15.001
mph - 91.25
the temps ranged from 91 for the first run to 86 on the last run
the humidity ranged from 60 on the first run to 80 on the last run
average barometer 29
also, my posi didnt work for me.
I have videos if someone can host them for me. thanks.
any other ppls times with their similar setups would be nice. thanks.
i would appreciate anyone giving me some ideas as to what i could do differently.
160 Thermostat
corvette 02 sensor
first run:
rt - .237
60 - 2.482
330 - 6.706
1/8 - 10.160
mph - 71.42
1000 - 13.126
1/4 - 15.621
mph - 90.90
second run:
rt - .217
60 - 2.185
330 - 6.301
1/8 - 9.766
mph - 71.06
1000 - 12.705
1/4 - 15.262
mph - 90.35
third run:
rt - .234
60 - 2.120
330 - 6.153
1/8 - 9.562
mph - 72.13
1000 - 12.505
1/4 - 14.985
mph - 91.37
forth run:
rt - .204
60 - 2.117
330 - 6.153
1/8 - 9.566
mph - 72.00
1000 - 12.516
1/4 - 15.001
mph - 91.25
thats pretty good times for a 305 tpi with an automatic tranny.
what gears do you have? you should either have 2.73's or 3.42's, from the good times and mph i would think u have the 3.42's.
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Car: 1991 Z28 - 2000 Z28
Engine: L98 - LS4
Transmission: 700R4 - 4L60E
Axle/Gears: 3.23's - 3.73's
Mine came with 3.23's factory. Look in your center console on the underside of the lid - it should either be a GU2 or a GU5 code.
Here's a timeslip from my car pretty much stock, mods were: 1LE Alum. DS, K&N's, gutted air box, 13* base timing, gutted cat.
60'... 2.02
330'... 6.244
1/8... 9.745
MPH... 69.54
1000'... 12.785
1/4... 15.355
MPH... 87.76
HTH
60'... 2.02
330'... 6.244
1/8... 9.745
MPH... 69.54
1000'... 12.785
1/4... 15.355
MPH... 87.76
HTH
Car: 1986 IROCZ
my code is gu5 and my timing is still at 6 degrees...any ideas as to what i could do next. i was thinking cam and new aluminum heads with roller rockers
Car: '86 Transmaro
Well said, I have the exact same setup except mine is a Trans Am. I dumbly rebuilt my 305 instead of just yankin it out and throwin a 350 in. Oh well, live and learn. My times were high 16's and low 17's. Mainly due to the fact that my exhaust has holes and my intake box has a hole as well.
Car: '86 Transmaro
ambainb
04-25-2016 09:21 PM
mustangman65_79
08-11-2015 03:17 PM
