325-50-15 BFG DRs
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
325-50-15 BFG DRs
Think they will fit?..i currently run 275-60-15 with mucho room to spare..Anyone ran these before?..looks like there 28x11.50s from what dimensions ive read...Anyone gimme some insight? thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just under 28" tall and about 12 3/4" wide across the section. Your 275/60 tires are just over 10 3/4" wide and are 28" tall. If you have an extra inch on either side of the sidewalls then they should fit. The only way to tell for sure is to install them. Asking someone else will only help if they use the same rims with the same backspacing as you have.
