Autocross spring rates
What spring rates are the hot setup for Autocrossing. Please don't tell me to get eibachs or hotchkis springs I need actual spring rate numbers that work. Eibachs or Hotchkis or any other spring package will not work for my application as I am installing screw jacks at all 4 corners.
Thanks for your help
Ric
Ric
I have been told that the stock 1LE swaybars and springs were good for autocross. I ran an 88 IROC with the stock bars and springs and did pretty well against newer cars. I now drive an LS1...
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Re: Autocross spring rates
I also autocross in the STX class so I can't run R-compound tires and of course don't have as much grip (also can't run tires wider than 245).
Edit: I think Sam said the thirdgen he won with in ESP last year (now sold to a local guy) has 850# front springs. Don't remember what's on back.
Thanx for the info.
What is the ride like with the 650 lb springs up front. rougher than stock, like stock or like a lumber wagon?
I am surprised that you are experiencing oversteer with that light of a spring in the rear and a heavy spring up front.
What type of shocks are you using and what do you think about the AGX shock and struts from KYB rears 8 settings front 4 settings.
Ric
Ric
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Thanx for the info.
Thanx for the info.
I don't know how the KYB's are with F Bodies, but I had a set on my Sentra SE-R, and they're pretty popular with other people who have the same car. They aren't too bad as long as you don't go too crazy with high spring rates.
92rsvortec350
19
10-09-2015 09:39 AM
Dragonsys
09-25-2015 03:51 PM
