Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
post your 1/4 miles times here. stock/moded
Old 05-11-2006, 06:37 AM
  #51
S!MON's Avatar
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
13.4@108mph before the crash.
Mods in sig.
after the new build up with a complete new exhaust (dual 2.5" instead of on 3") and tremendous weight shaving (tubular frame) it should see good 12s.
Greetz
Simon
Old 05-11-2006, 05:30 PM
  #52
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
14.17 @ 95.25 w/1.97 60'
gutted cat ,tci trans w/app.2000stall ,2.77 limited slip other wise stock l98
new time: 13.96 @96.71 1.932 60'
magnaflow ultra flow 3" muffler
m.t. dr's
Old 05-12-2006, 11:10 AM
  #53
drag1LE's Avatar
Car: 1991 Camaro 1LE Z28
Engine: 6.0L
Axle/Gears: Ford 9" 4.33
Originally Posted by brutalform
Welcome to TGO, drag1LE. What induction system are you using with your combination? Just wondering, when I saw your gear ratio.
Whoops - maybe I was supposed to do it this way.
Anyhow - I'm carbureted, Holley 750. Victor Jr. intake.
Old 05-15-2006, 01:30 PM
  #54
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Stock L98
With stock manifolds and converter it went 14.01 @ 96 mph.
Only mods were magnaflow cat, catback, slp runners ported, afpr and k&ns with ported filter box.
Street tires at 28 psi. 9.8 inch wide.
Old 05-28-2006, 04:15 PM
  #55
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
88 GTA L98 stock but rebuilt 700R4 and stock 3.45 ausie 9 bolt
-stock w/raven muffler and K&N filter..14.8@ ????
-gasket matched to stock napa gaskets (heads and lower intake) w/ same mods, Mickey DR (15psi) and 125 dry shot...13.0 @105 mph
Old 05-28-2006, 05:43 PM
  #56
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
11.82 @ 115. installed new 8 inch custom ati converter , hoping for low 11's
Old 05-29-2006, 01:38 PM
  #57
1320stompers's Avatar
9.34@148mph
9.34@148mph at 3200lbs stock suspension
355 sbc 72mm turbo blow-thru carb by CSU Carbs
NMCA class car- Street Race
check out my profile 1320stompers
www.1320stompers.com
Old 10-14-2007, 10:46 PM
  #58
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Re: post your 1/4 miles times here. stock/moded
best 13.1 @105 and 1.94 60ft
350 bored 40 10.1 to1 cr
trick flow heads perfrom rpm intake
750 holley dp msd wires
summit hei dist .473 .486 zcam
rollar rockers 4.10 posi rear
newly rebuild 350 turbo shift kit
jegs 2500 stall Heddman 1 5/8 shorty hedders
flowmasters ets street tires
Old 10-14-2007, 11:07 PM
  #59
car_fixer's Avatar
since somebody got this out of lost threads land, what the heck
87 camaro z28 , 1 piece rear main block, 383, 13.0 comp ,solid roller, holley strip dominator intake, custom built 750 carb, stock suspension pickups, tubular lower a arms in front, random tech torque arm , 9in housing with 12 bolt center section (dont ask i dont know where it comes from) tubular lower arms relocated lower rear pickups for correct geometry, m/t 10.5w slicks
best rt. .009
best 60. 1.35
best 1/8 to date 6.1
best 1/4 w/o nitrous 10.67
best 1/4 with 225 shot 9.77 at 132 (had to lift before 1/8 to avoid crossing centerline should go low 9's)
best mph 146 (after standing it on the bumper and having to lift since i thought it turned and it unloaded the rear tires too)
Old 10-14-2007, 11:20 PM
  #60
EvilCartman's Avatar
Car: '82 Z28
Originally Posted by intex1982
in sig
Too bad you didn't include your sig
As for me, new best from the last time I posted in this thread.
1/4 mile on the motor 11.87 @ 114 mph
on the bottle with a pinched feed line causing the car to actually slow down since it was so rich: 11.41 @ 113 mph
Old 10-14-2007, 11:21 PM
  #61
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
you guys do know that the last post before yours was like a year & a half ago?
Old 10-14-2007, 11:24 PM
  #62
Car: '82 Z28
Umm, yes?
Old 10-14-2007, 11:34 PM
  #63
intex1982's Avatar
who cares
Old 10-14-2007, 11:37 PM
  #64
who cares
Children
specialized
06-18-2022 09:26 AM
Vintageracer
01-10-2020 05:33 PM
Derick15
Members Camaros
08-20-2015 10:19 AM
IROCZ1989
08-19-2015 08:15 AM
Quick Reply: post your 1/4 miles times here. stock/moded
