squirrly car
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
squirrly car
well after running last night my car my car drives itself all over the lane . back end feels like its floating around. i just installed spohn LCA's,and relocating brackets , panard rod. S&W race cars SFC's and adj. torq arm, and 26-10.5-15 et streets at 18psi. it hooks ok but the back end seems to float. HELP !
mike
mike
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Don't always blame the car. My car hooks and runs good during the summer. At the end of the year when the track starts to get cold I have no traction at all until some heat is built up in the track. Sometimes it feels like I'm about to do a lane change.
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
my car feels like its on snow at the top of the track....but it doesnt start doing it until the pressure gets around 10-12 psi....which is where it gets the best traction its kinda scary until you get used to it hehe
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
383,
You're not running enough tire pressure. Go back up in pressure, also check your tire pres gauge against others to see if it's accurate. You should be using a good one like the one Moroso makes. Be sure you're checking yours against a known accurate one, not a pencil type gauge. Try a harder burnout with the higher pressure and stage with a bit less rpm's too.
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
thanks for the replys . with my street tires on it feels good , just not use to the feel of slicks any more. . i had 16 psi in them and it is a good and accurate gauge. havn't run on tires like that in 18 years. ( oh no,.... might be showing my age)
mike
mike
Linson
08-21-2015 02:12 PM
