1st run on g-tech
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
1st run on g-tech
just did my first run on the car on the g-tech . 13.57@106.9, 2.35 60"time .need more help getting out of the hole . but i thought it was pretty good . i live at 4800' eleavation (correction time of 1 full second) plus i still need to install the NOS cheater system .hehehe . any thoughts on getting off the line better . just put on 26-10.5-15 et streets tonight , was out breaking them in
mike
mike
The new Gtechs now have a 60' feature.
However it seems to me that they are inacurate. 4.11 gears and 10.5" ET Streets should give you a much better short time...if you werent spinning them. I guess that is possible given the temp outside.
ET Streets like to be very hot. It is possible that your 4.11 gearing isnt allowing you to heat them up enough in the burnout using 1st gear. If they are spinning on your launch, it may be time for a line lock so that you can use 2nd gear for burnouts.
Dont be afraid of a big burnout with these tires. In my experience the longer you heat 'em, the more they stick. Do a smokeshow that would make John Force crack a grin and try another run.
-Doug
-Doug
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
ya its the new g-tech compition. it was 25* outside and no burnout to warm them up . just driving around to find a spot to run then run . looked today and there is about 10 to 12 ' of black at the launch. i left at 4500rpm. compared to the street tires that i run and can't crack the secondaries in first , i was trying to figure out how to launch .
when we ran the g-tech on a friends camero in the 1/8th in augest his time slips were 7.0, 7.1 and the g-tech read 7.2,7.3 so we were impressed with it
going to run a chevy luv tomarrow . it has a tpi 350 and turbo in it . it has run some 13.0 on the old style g-tech i'll let you all know what happens
mike
mike
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
i thought the same thing but it is built to be a n2o motor. the plugs are 3 steps to cold and i have done no tuning other than set timming at 35* total at 3000rpm. the ex. are ported heavily and the intakes mild and the ring gaps are set bigger but it still should be pulling harder i think . any thoughts or suggestions to try . i also need to get my 60 foot times down.
mike
mike
Fast355
12-02-2016 06:33 PM
eightsixseven
08-14-2015 03:09 PM
