Weighed My Camaro in today
Car: 1989 Iroc Z L98
3100 pounds without me in it. I am pretty happy with the weight. What do you guys think I will be running with a 350HO with 330 horsepower and 380 ft lbs torque. The motor seems to pull awefully hard. I am hoping for high 13's with a 3000 stall and 3.73's.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Why did you weigh it without you in it? The car won't go down the track by itself. Weight it with everything you need to go racing with; driver, helmet, fuel etc. Then you will have the true weight that the engine needs to push down the track. That will be your race weight. After that find ways to remove race weight.
Unless you get a lot of tire spin there's no reason why you can't get high 13's.
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Thats a soild 300+ lbs lighter than my car deducting my 230lbs from my 3688lb race weight but Im full weight minus jack and spare with a 1/4 tank, Im jealous!!!
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
My car was right at 3180 with everything (including me) but a hood. I removed the backseat, added a glass lift-off cowl, took off the a/c, and pulled the subs out and i'm at 2950 (according to the grain elevator's digital scale).
Originally posted by Mark A Shields
Just wondering what options you have, anything you've taken out?
removed all smog equipment
i dont run a cross flow muffler (i imagine this saves quite a bit, just a dynomax bullet muffler)
removed all a/c equipment
removed a/c / heater suitcase from firewall (still have all heater stuff including core, might switch back to having heat later on)
removed cruise control
removed power steering and will be swapping in an s10 gearbox
i dont currently run a stereo, i have a gauge cluster where the radio went
aluminum radiator
removed jack/spare tire
things still to do:
remove back seat
get rid of all spare parts in back
fiberglass hood
lightweight wheels
aluminum water pump
mini starter
for some reason it is stuck in my head that once i get my car tuned it will run a 13.7 i dunno why. i have a feeling traction will be tough but we'll see.
Seth
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
check out my sig as we're pretty close, but you do have gears on me, so yeah you'll definately be low-mid 13's.
Originally posted by 89WS-6
Man, what did I do wrong? Mine was 3120 with no seats but the drivers (at that time) no A/C, no Smog, and mine is a 305 TBI. hmmmmmmmmmmmmmmm,
Car: 88 IROC
Transmission: auto
Might have to do with the 84's having lighter bumper. Not sure about that one though so someone can double check this. My 84 weighted in at 3180-3200lbs with a lot of stuff removed: jack and spare, T-5 tranny-a lot less weight then auto, no air, power nothing except rear hatch, no smog, front sway bar removed at the time, carpet and padding in rear cargo area removed. That's with a 400 block and iron heads(don't know it 400 weighs more then a 350, but probably not). Since then i got a fiberglass hood and stewart stage 2 alum. pump.
Ontogenesis: your weight seems hard to believe, the scale must have been off. your car is at 2950 just from removing a/c and a glass hood? maybe if you got a v-6.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
If the car comes out at 3300lbs with you in it and it actually has 330hp, it should run about 109mph, or a low 13 second run (or better).
92camaroJoe
08-13-2015 06:07 AM
