1/4 mile, what do you thinks she will run
Car: 91 firebird now
Transmission: 5 speed
Im looking to get a 92 Trans Am and I was just wondering what you guys think it would run, they are supossed to have 240hp. After I get her I want to swap the auto tranny out for a t56 out of a 94-97 f body.
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
If you put a 6 speed in that car you should be able to cut some low 14's easily if you can drive that thing halfway decent.
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
i believe the 92 350 had 245horses. The 700R4 kills 20% of your flywheel hp and the T56 supposedly only takes about 12-15% away, so your looking at about a 20 hp gain at the wheels by swapping the manual. If you can drive pretty good I'd expect low 14s.(if you swap in some good gears while your at it) With a 6 spd I'd recommend 3.73 or 4.11
Car: 1991 Camaro Z28
Engine: 350 L98
I just ran my camaro at the track yesterday. It's pretty much all stock I ran a best time of 14.416 I believe. Plus it snowed that morning and it was cold all day at the track.
Pretty good for my first time out.
Originally posted by MdFormula350
really i never knew 3.73's could hurt..
i guess maybe somewhere in the 3.4X would be better than..
i have the stock 3.23s and my cars seems like it dies half down the track..
When I had the 3:73s, I didnt like it. It revved too fast. For auto guys , they may like it. But for the manual guys, I say stay around 3:42ish. Of course, 3:42 rears are hard to come by. So I settled for a 3:23, which I don't regret at all. Like I said before, the car stays in 3rd through the traps (just barely)
i think that i might have to differ with the "your first time out"idea. the first time in my life that i ever ran my car was the best pass to date. which by the way was a 14.12 with the mods listed in the sig.
Originally posted by ir0cflamez
Your first time out with it? high 14s cuz you wont know the car.
Once you get to know it, probably mid 14s.
3:73s are too much for TPI. Trust me, been down that road. They actually made my time worst.
YUP. Im there right now
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
6-speed = 6 chances to screw up??
And there are only 5 shifts in a 6 speed assuming you start in 1st gear
3rdgenparts
08-06-2015 09:03 AM
